Symmetry with respect to a circle
4 replies · 6K views · last reply
mrbohn1
Could someone please just explain a step in a proof for me?
Suppose x and y are symmetric with respect to a circle, and a,b and c are three points on the circle. This means that:
(x,a,b,c) = ([tex]\bar{y}[/tex],[tex]\bar{a}[/tex],[tex]\bar{b}[/tex],[tex]\bar{c}[/tex])
The writer then says:
"symmetry only depends on the circle, and not on the points, so if x and y are symmetric then:
[tex]\frac{x-b}{a-b}[/tex] = [tex]\frac{\bar{y}-\bar{b}}{\bar{a}-\bar{b}}[/tex]"
I understand why this would be if the points were on a straight line, as then you could choose c to be the point at infinity, and the cross ratio would reduce to this. But why is it also true for a circle?
You need to give us some more information. Are we talking about a circle in the real plane? What's the significance of [tex]\bar{y}[/tex]? That suggests conjugates, so maybe we're not talking about circles in the real plane. And what does (x, a, b, c) denote?
Fair enough!
This is a complex analysis problem - the circle is in the complex plane.
If x, a, b, c are complex numbers, then (x,a,b,c) denotes the cross ratio:
[tex]\frac{(x-b)(a-c)}{(x-c)(a-b)}[/tex]
Two points x and y being symmetric with respect to a circle means that if a, b, c are any three points on that circle, then:
(x,a,b,c) = [tex]\overline{(y,a,b,c)}[/tex]
(ie. the cross ratio of x, a, b, c is equal to the complex conjugate of the cross ratio of y, a, b, c ).
So: [tex]\frac{(x-b)(a-c)}{(x-c)(a-b)}[/tex] = [tex]\frac{\overline{(y-b)}\overline{(a-c)}}{\overline{(y-c)}\overline{(a-b)}}[/tex]
But the text says that we can choose the points a, b, c such that some of these terms cancel and we get:
[tex]\frac{(x-b)}{(a-b)}[/tex] = [tex]\frac{\overline{(y-b)}}{\overline{(a-b)}}[/tex]
I don't understand this - as far as I can see this would only be possible by choosing c to be infinity, but the circle does not contain the poiint at infinity.
Is it considered bad form to post a reply to your own question to get it back to the top of the board?
I had one class on complex analysis in grad school, but I have to confess we didn't cover any of the ideas you've presented, such as symmetry wrt a circle or the cross-ratio business.
So looking at what you have and where you want to go, it seems that you want the a -c and x -c factors to cancel in the ratio on the left, and the a -c and y -c (conjugate) factors to cancel in the ratio on the right. For the one on the right, if you choose a = y those factors cancel, but on the left what seems to work is choosing a = x. You said that one could choose a, b, and c, but I don't think you can choose a to be simultaneously equal to both x and y, so that doesn't seem to help.
What bothers me is that the word "symmetry" is used in this problem, but I don't have a clear picture in mind of where x and y are located on the circle. I would think that x and y being symmetric with respect to the circle means one of the following:
  1. Re(x) = Re(y) (the points are directly across the real axis from one another so that x = conj(y))
  2. Im(x) = Im(y) (the points are directly across the imaginary axis from one another)
  3. Arg(x) = Arg(y) + k*pi, where k is an integer (symmetry about the origin)
Is symmetry with respect to a circle what I have described here?
Sorry I'm not able to provide more help.
