Tangent line toa curve that minimizes the area of a triangle
The problem involves finding a point on the parabola defined by the equation y=1-x^2, where the tangent line at that point creates a triangle with the smallest area in the first quadrant. Participants are exploring the relationship between the geometry of the triangle and the properties of the parabola.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the area of the triangle in terms of its base and height, with some suggesting different formulations for the area. There are attempts to differentiate the area function to find critical points, and questions arise regarding the application of the quadratic formula and the correctness of earlier steps.
Some participants have made progress in reformulating the area equation and differentiating it, while others are still grappling with earlier steps and seeking clarification on their approaches. There is a mix of insights and corrections being shared, indicating an active exploration of the problem.
Participants mention constraints related to homework rules and the need to find critical points for optimization. There is also a reference to a separate problem involving implicit differentiation, which may be affecting focus on the original problem.
NyteBlayde
Sorry if the title is a bit vague :/
The Problem: Find the point on the parabola y=1-x^2 at which the tangent line cuts from the first quadrant a triangle with the smallest area.
Relevant Equations: y = 1-x^2 ; y' = -2x ; A= 1/2bh
I'm basically stuck near square one, I found this site through a google search of the above problem and found a similar topic here, but it wasn't quite the same (or at least I didn't see how to relate my problem to it) so I'd like to ask someone to help me out here :)
What I have so far is that the derivative of the tangent line to the curve is -2x. Where should I go from here?
Aha
Through a closer look at the problem and running through it a lot in my mind and looking again at the other topic I think I have figured it out. Thanks to anyone who was or is working on replying (if any, lol). All I had to do was change A= 1/2 bh to A= 1/2 xy and I know that any point on the parabola is P(p,1-p^2) so I was able to go from here :) Always makes me feel good when I figure things out :D
Ah! I was trying for you on/off :p GJ! At least now I've gained another way of approaching random problems.
hmmm, i may be stuck again, if i find A(p) by setting it equal to 1/2 * (p^2+1)/2p * (p^2+1) i get that A(p) = p^4+2p^2+2/4p and by differentiating this to find its critical numbers to find a min, i get -4p^2+40p+8/4p^4. Now, in order for this to be 0, -4p^2+40p+8 has to be 0. I've tried to use the quadratic formula for this but I keep getting weird roots that don't even make it 0. Am I doing something wrong? sorry for the early cancellation lol :/ :stumped:
I'll keep trying but any help is appreciated :)
I'm not sure what you did, but this is how I'm starting out.
[tex]A=\frac 1 2 xy[/tex]
[tex]y=1-x^2[/tex]
[tex]A(x)=\frac 1 2 x(1-x^2)[/tex]
[tex]A(x)=\frac 1 2 (x-x^3)[/tex]
[tex]A'(x)=\frac 1 2 (1-3x^2)[/tex]
Setting it equal to 0, and then plugging in the values found into my y-eq.
Wow i completely overlooked that :/ I used a wrong reference point, man i did a lot of extra worthless work :/ at least it was kind of fun and interesting lol Thanks a ton I'll see if I can finish with that, I'm working on a couple other problems now, 3 to be exact and I think I'm doing ok, only 1 is giving me problems right now :/ maybe you can help :)
it appears simple : find highest and lowest points of curve x^2+xy+y^2=12
By implicit differentiation i get that y' = 2x+y / 2y+x . Is that right? if so I don't know what i can do to move on with the problem. I suppose I have to make it zero somehow ?? its always the simple concepts that get me...
Lol, at least you got both of us started on that problem. I was lost on what to do :-]
I think you forgot the product rule for your middle term, xy. You weren't given any points?
Well by just plugging in values, the points are P(2,2) b/c that equals 12.
no the exact wording is: "Find the highest and lowest points on the curve x^2+xy+y^2=12"
I did D(x) (x^2 + xy + y^2) = D(x) (12)
= 2x + y +xy' + 2yy' = 0
the y + xy' is a result of the product rule (unless i messed up)
=2yy'+xy' = 2x+y
=y'(2y+x) = 2x+y
= y' = 2x+y / 2y+x
=2yy'+xy' = 2x+y
=y'(2y+x) = 2x+y
= y' = 2x+y / 2y+x
Ah yes you're right, I messed up sorry.
heh np, I've done worse :P
Well the way I went about this is, that when y=0 for f', then that tells me that my f is at a max/min, so [tex]y'=\frac{2x+y}{2y+x}[/tex]
set y=0, that gives me y'=2, which is the same as P(2,2) from which our original equation equals 12.
ah, didn't think of that. what about the other extrema? set x=0 ? that would give me y=1/2 no?
I'm not sure about that, I wish I could plug it into my calculator. LOL
lol same, quick question, from y'=2, how did you get P(2,2) I may just be overlooking that aswell. I thought i got it but now i realized i messed up.
Ah, I just read my Calculus book and we need to do it over again. It says to set y'=0, and basically just set the numerator equal to 0.
[tex]y'=0=2x+y[/tex]
[tex]y=-2x[/tex]
So plug that back into our original equation ...
[tex]x^2+x(-2x)+(-2x)^2=12[/tex]
Set it equal to 0 and solve for x. Then plug it back into the numerator of our y'.
lol ok, from where? :)
Ok sorry, refresh! I just updated after figuring out what my book did.
so 3x^2-12=0 ?
wait wait wait duh, can't i just go x^2=4 and my roots are +/- 2 ??
Yes, those are the roots and just plug back into the numerator of y'.
Are there answers and what book is this from?
Why do I need to plug them into y' ? don't i just use them as x values for the original equation and find y values and see which point is smaller?
And no I don't have answers for these problems in the student edition, it's Single Variable Calculus Fourth Edition by James Stewart (editor?/author?) oh, they're on pg 310 of that book BTW :)
I'm not sure if this explanation will suffice, but we're trying to solve for where y'=0, so we found that it will be 0 when y=-2x. By using our original equation, we find the x values in which y is at a max and plug it back into the numerator of y' that makes it 0.
(Worst explanation ever, lol.)
neither 2 or -2 make it 0 though.
Hm, the thing is we set y'=0 already, so we did solve for our condition. We used it to find the max/min of our original equation.
so what do I do with +/- 2, are these the y coords for my min/max? so all i would have to do is find the x value?EDIT: errr sorry, x coords for the min/max so id have to find the y values? which would just be: max: (2,2) min(-2,-2) ?
No x=+/-2
So go back to the numerator for y'=0=2x+y and plug it in there, and it you will get the y values for your max/min.
No, y'=0=2x+y
x=+/-2
y=-2x, P(2,-4) and Q(-2,4)
Ah, now see it satisfies our conditions that make y'=0
lol sorry, i was just doing a step twice, once on paper once in my head :P so min(2,-4) max(-2,4) correct?
EDIT: lol u beat me to it
3 down 1 togo :D, now i got to go finish that pesky area of a triangle one
thanks a ton for helping me lol, id be up much later if i was trying to go solo :/
back on the topic of the first question, u set 1/2(1-3x^2) = 0
so i should end up with 1/2 - 3/2x^2 = 0 and all i need to do is solve for x and then find my min right?
  • · Replies 16 ·
