Taylor expansion at infinity of x/1+e^(1/x)
The discussion focuses on finding the Taylor expansion at infinity for the function f(x) = x/(1 + e^(1/x)). The user initially attempts to find the expansion at zero using g(u) = (1/u) * (1/(1 + e^u)), where u = 1/x, but encounters difficulties due to the limit behavior of e^u. The conversation shifts towards using Bernoulli numbers and generating functions to derive the required expansion, with suggestions to express the function in terms of known series. Ultimately, it is clarified that the function does not have a Taylor expansion at infinity but may have a Laurent expansion instead.
  • Understanding of Taylor and Laurent series
  • Familiarity with exponential functions and their limits
  • Knowledge of Bernoulli numbers and their applications in series
  • Experience with generating functions in mathematical analysis
  • Research the properties and applications of Bernoulli numbers
  • Study the derivation and use of generating functions in series expansions
  • Learn about the differences between Taylor and Laurent series
  • Explore the behavior of exponential functions near their limits
Mathematicians, students studying advanced calculus, and anyone interested in series expansions and asymptotic analysis will benefit from this discussion.
Alv95
I have some problems finding Taylor's expansion at infinity of
<br /> f(x) = \frac{x}{1+e^{\frac{1}{x}}} <br />
I tried to find Taylor's expansion at 0 of :
<br /> g(u) = \frac{1}{u} \cdot \frac{1}{1+e^u} \hspace{10 mm} \mbox{ where } \hspace{10 mm} u = 1/x <br />
in order to then use the known expansion of \frac{1}{1+t} but the problem is that I can not do it because :
\lim_{ u \to 0 } e^{u} = 1 \hspace{10 mm} \mbox{ and not } 0Any ideas on how to do it? :smile: Thanks :smile:
You should express that denominator uas
\frac{1}{2+(e^{u}-1)}
\frac{1}{2} \frac{1}{1+ (e^{u}-1)/2}
Now if u is close to 0 (eu-1)/2 is close to zero and we can expand inthis
\frac{1}{2} \left(1-\frac{e^u-1}{2} +\left(\frac{e^u-1}{2} \right)^2+... \right)
Thank you very much Office_Shredder :smile:
I had thought of adding/subtracting 1 but not of factorising the 2 :redface:
Thank you again :wink:
... The problem is now that I get a different expansion depending on how far I go in the approximation ... those
\left( \frac{\cdots \, \, - 1}{2}\right)^n
change the first term of the expansion ...
EDIT: Sorry :smile: I should replace \left( \frac{e^u - 1}{2}\right) with his expansion, right? :smile:
EDIT: Done! Thanks :smile:
Do it in terms of Bernoulli numbers. Bernoulli numbers appear in the series for ##1/(e^x - 1)##. You need to get the series for ##1/(e^x+1)##, which you can do by expressing ##1/(e^x+1)## in terms of ##1/(e^x - 1)## and ##1/(e^{2x}-1)##; in other words, you need to express ##1/(y+1)## in terms of ##1/(y-1)## and ##1/(y^2 - 1)##.
For more on Bernoulli numbers, see, eg., http://mathworld.wolfram.com/BernoulliNumber.html
I don't know yet what Bernoulli numbers are (we don't do them in my school) :smile: Thanks anyways for your help :smile:
From what I have understood from Wikipedia (:rolleyes:) I should rewrite my function: \frac{1}{1+e^u} as a "generating function" so that it will then generate the required expansion ?
I get \frac{1}{1+e^u} = \frac{e^u - 1}{e^{2u}-1} but it is a little bit different from the standard forms of the generating functions ...
Any insight on Bernoulli numbers is welcome! :biggrin:
Google is your friend---look them up!
I would not write ##1/(y+1) = (y-1)/(y^2-1)##; that just makes the problem much worse!
Suppose I asked you to do the reverse, which would be to write ##1/(y^2-1)## in as simple a way as possible in terms of ##1/(y-1)## and ##1/(y+1)##. What would you do? Have you ever encountered partial fractions?
I don't think it matters whether or not you have seen Bernoulli numbers in your school; all that matters is that you are allowed (I suppose) to go to the library and look things up in a book, or (nowadays) go on-line to find information. Just *cite* your sources, whether they are books or web pages.
This function doesn't have a Taylor expansion at infinity because it diverges in that limit. Did you perhaps mean a Laurent expansion instead?
ok :wink:
I have got:
\frac{1}{y^2-1} = \frac{1}{2(y-1)}-\frac{1}{2(y+1)}
therefore:
\frac{1}{y+1} = \frac{1}{y-1}-\frac{2}{y^2-1}
My function is then:
\frac{1}{e^u+1} = \frac{1}{e^u-1}-\frac{2}{e^{2u}-1}
Alv95 said:
ok :wink:
I have got:
therefore:
OK, so take it from there!
@ Vela
I have found an oblique asymptote:
y = \frac{x}{2} - \frac{1}{4}
