Taylor Series Expansion for f(t) and G(x) with Convergence Analysis"
The discussion revolves around finding the Taylor series expansions for the functions f(t) = 4/(1 + t^2) and G(x) defined as the integral of f(t) from 0 to x. Participants are exploring the series expansions and the convergence analysis of these functions.
  • Participants discuss the power series expansion for f(t) and G(x), with some providing their derived terms. Questions arise regarding the correct formulation of the general term for G(x) and the application of the ratio test for determining the interval of convergence.
There is an ongoing exploration of the interval of convergence for the series related to G(x). Some participants have provided guidance on applying the ratio test and testing the endpoints of the interval, while others express confusion about specific steps in the process.
Participants are navigating issues related to the correct identification of variables in the series expansions and the application of convergence tests. There is mention of using the alternating series test (AST) for endpoint convergence analysis.
hereiscassie
Let f be the function given by f(t) = 4/ (1 + t^2) and G be the function given by G(x) = {Integral from 0 to x} f(t)dt .
(a) Find the first four nonzero terms and the general term for the power series expansion of f(t) about t = 0.
(b) Find the first four nonzero terms and the general term for the power series expansion of G(x) about x = 0.
(c) Find the interval of convergence of the power series in part (b). (Your solution must include an analysis that justifies your answer.)
for part a I got:
4 - 4t^2 + 4t^4 - 4t^6 +...+ [(-1)^n](4)t^2n +...
and for part b I got:
4x - (4x^3)/3 + (4x^5)/5 - (4x^7)/7 +...+ [(-1)^n](4)(t^2n)/(2n + 1) +...
how do u do part c? I don't know what to do
Apply a ratio test to your series to get the interval of convergence. Your general term for b should have an x in it and I don't think the power is quite right.
Use the ratio test or nth-root test on your series and determine the interval over which the series will converge. Finally, figure out somehow whether the series converges on the endpoints of that interval.
For your general term in part (b), it's x, not t. And yes, apply the ratio test, and then test the endpoints using AST.
I fixed part b and i got:
4x - (4x^3)/3 + (4x^5)/5 - (4x^7)/7 +...+ [(-1)^n](4)(x^(2n +1))/(2n + 1) +...
and I am still slightly confused in part c...
I did the ratio test and i can't get past
\stackrel{lim}{n \rightarrow \infty} \left|\frac{(-1)x^2(2n +1)}{2n +3}|
srry, its supposed all in absolute value, i still don't know how to work latex
Remember that the x acts like a constant here since you're taking the limit as n, not x, goes to infinity. Also, you have an absolute value so you can just erase the (-1)^n factor.
oh right!
so after that i get
x^2 < 1 and then x will equal -1 and 1 right?
and then the IOC would be -1 < x < 1
but then how would i test these boundaries using AST?? do I use the sum i had with these?
substitute x with 1 or -1 in the sum, and see if it is convergent (as a sum of a sequence)
for example for x=1 your sum is:
S=\sum^{\infty}_{0}\frac{4(-1)^{n}}{2n+1}
Thank you so much! you helped me a lot!:)
  • · Replies 27 ·
