Taylor Series Expansion for the Relativistic Factor of Momentum
The discussion focuses on deriving the Taylor series expansion for the relativistic factor γ, specifically for small velocities (v) around v = 0, using the equation γ = 1/SQRT(1 - V²/C²). Participants clarify that substituting X = V/C transforms the equation to γ = 1/SQRT(1 - X²). The correct expansion involves calculating derivatives at X = 0, leading to the Maclaurin series representation. Key corrections include ensuring accurate derivative calculations to avoid sign errors in the series expansion.
  • Understanding of Taylor series and Maclaurin series
  • Familiarity with the concept of relativistic momentum
  • Knowledge of calculus, specifically differentiation
  • Basic understanding of the Lorentz factor γ in special relativity
  • Study the derivation of the Lorentz factor γ in special relativity
  • Learn how to compute Taylor series expansions for various functions
  • Explore the implications of relativistic effects on momentum and energy
  • Practice solving problems involving Maclaurin series in physics contexts
Students and educators in physics, particularly those studying special relativity, as well as anyone interested in mathematical methods applied to physics problems.
leejqs
Using the technique of Taylor expansion, find an approximate expression for the relativistic factor γ for small v (i.e., expanded around v = 0) that is correct to order v2.
γ=1/SQRT(1+ V2/C2). But in class, my professor just substituted X=V/C, so the equation became γ=1/SQRT(1-X2).
I tried to expand the function γ(v) with v at 0...
γ(v)=1+γ'(0)(X-0)+(1/2)γ''(0)(X-0)2
However, this expression wasn't correct. I'm not really sure how else to expand it! Any help would be much, much appreciated, thanks!
With that substitution, you get y = 1/sqrt(1 + x2).
This is really y(x) with x at 0. If v = 0, then x = 0. It's very likely that the sign error above is affecting what you got for your Maclaurin series.
Sorry for that typo! The actual function is y=1/SQRT(1-V2/C2).
In finding the parts of this maclaurin series, I have...
y(0)=1/SQRT(1-X2)(X-0)0=1
y'(0)=(1/2)(1-X2)(-3/2)*X2
y''(0)=(1/2)(1-X2)(-3/2)*X2+(1-X2)(-3/2)*(1-X2)(-5/2)*3X4
Sorry for my lack of showing my work, but I believe those expressions are right
when using the yn(v)=[f(n)(X0(X-X0)n]/n!
how to Put the Boolean function q'r + p'q' + pq'r' into DNF and find a simpler representation for the function using a Karnaugh map. Show the output of this simpler function is the same as in question 1 for p = 1, q = 1, r = 0.
Your derivatives are wrong because you're mixing in stuff from the series expansion. You should have:
y(X)=1/\sqrt{1-X^2} \rightarrow y(0)=1
y'(X)=X/(1-X^2)^{-3/2} \rightarrow y'(0)=0
and so on. You then plug these values for y(0), y'(0), y''(0) into the series expansion.
