Estimating Remainders for Taylor Series of Sin(x)
The discussion clarifies the construction of the third-order Taylor polynomial for sin(x), which includes terms up to x^3, specifically expressed as x - x^3/3!. The remainder theorem for Taylor series indicates that the remainder R_n(x) is calculated using the next term in the series, which for sin(x) is x^5/5!. It is established that for sin(x), the third and fourth-order Taylor polynomials are identical due to the vanishing x^4 term, leading to equal remainders R_3(x) and R_4(x). The discussion emphasizes the importance of finding an upper bound for R_4(x) to assess the approximation quality of both T_3(x) and T_4(x).
  • Understanding of Taylor series and polynomial expansions
  • Familiarity with the sine function and its Taylor series representation
  • Knowledge of the remainder theorem for Taylor series
  • Basic calculus concepts, including derivatives and factorials
  • Study the derivation of Taylor series for various functions
  • Learn about the Lagrange form of the remainder in Taylor series
  • Explore the implications of higher-order derivatives on Taylor series accuracy
  • Investigate the convergence of Taylor series for different types of functions
Students and educators in mathematics, particularly those focusing on calculus, as well as anyone interested in understanding Taylor series and their applications in approximating functions.
member 508213
I am just trying to clarify this point which I am unsure about:
If I am asked to write out (for example) a third order taylor polynomial for sin(x), does that mean I would write out 3 terms of the series OR to the x^3 term.
x-x^3/3!+x^5/5!
or just
x-x^3/3!Also, I have a question for the remainder theorem for taylor series (or Lagrange). If I am doing the remainder for a a polynomial for sinx written out as x-x^3/3!, the remainder theorem says use f^n+1(c)(x-a)^n+1/(n+1)!...but for sinx it skips the x^4 term so how would this work? I would assume you would just use the next term: (x^5/5!) but it does not say this anywhere I can find so I am unsure.
Thanks!
The 3rd order taylor series for sin(x) would only be up to the x^3 term.
In the remainder formula, n refers to the number of terms, not necessarily the powers. In this case x is the first term, -x^3/3! is the 2nd term, and x^5/5! is the 3rd term.
Third order in the general case means up to the ##x^3## term. When you remember that a lot of terms are zero in your expression because they involve the sine of zero, maybe it becomes more clear.
A tiny bit of "wordsmithing" to be clear: "up to and including"
The n has the same meaning as in "expansion to order n", but the formula is true for every n so it does not really matter as long as you use the same n for both expansion and error.
It is 0*x4. There is nothing special about the zero.
By definition, the remainders are given by
\begin{align*}
R_3(x) &= \sin x - T_3(x) \\
R_4(x) &= \sin x - T_4(x)
\end{align*} where ##T_n(x)## is the n-th order Taylor polynomial. For ##\sin x## about x=0, you have ##T_3(x)=T_4(x)## because the ##x^4## term vanishes; therefore, the remainders ##R_3(x)## and ##R_4(x)## have to be equal. Typically, however, you don't calculate the actual remainder. Instead, you find an upper bound. If you find an upper bound for ##R_4(x)##, it would give you an idea for how well ##T_4(x)## approximates ##\sin x##, and since ##T_3(x)=T_4(x)##, it also tells you how well ##T_3(x)## approximates ##\sin x##. So why find an upper bound for ##R_4(x)## instead of ##R_3(x)##? It's because you generally get a better, more stringent estimate for the upper bound by using the formula for higher-order remainder.
  • · Replies 19 ·
