Finding Taylor Series for f(x) = $\frac{x^2+1}{4x+5}$
The discussion focuses on finding the Taylor series for the function f(x) = (x² + 1) / (4x + 5). Participants suggest partitioning the function into two parts, f1(x) and f2(x), and using their respective Taylor series to derive the overall series. A key method involves differentiating f directly and identifying a pattern, leading to the expression f(x) = f(x₀) + f'(x₀)(x - x₀) + Σ gᵢ(x₀)(x - x₀)². The discussion also highlights the use of geometric series to express the function in a power series format, particularly for the range -1 < x < 1.
  • Understanding of Taylor series expansion
  • Familiarity with geometric series
  • Basic calculus, including differentiation
  • Knowledge of power series representation
  • Study the derivation of Taylor series for rational functions
  • Learn about geometric series and their applications in power series
  • Explore differentiation techniques for series expansion
  • Investigate convergence criteria for Taylor series
Students studying calculus, mathematicians interested in series expansions, and anyone looking to deepen their understanding of Taylor series for rational functions.
annoymage
find the taylor series for the function
f(x) = \frac{x^2+1}{4x+5}
N/A
how to do this?
1st attempt.
i did turn it this term
\frac{x}{4} + \frac{-5x+4}{16x+20} can i turn this to taylor series?
maybe i know how to make \frac{-5x+4}{16x+20} to taylor but
\frac{x}{4} + \frac{-5x+4}{16x+20}??2nd attempt.
should i differentiate it until i get fn(x) form??
what to do what to do?
If you can partition your function into two functions like f(x) = f1(x) + f2(x) and you have the Taylor series for both f1 and f2 then the sum of these is the Taylor series for f.
You can also differentiate f directly and look for a pattern that will allow you to write the series as
f(x) = f(x_0) + f&#039;(x_0)(x-x_0) + \sum_{i=2}^{\infty}{g_i(x_0) (x-x_0)^i}
where gi is a fairly simple function having parameter i.
Certainly, the basic definition of "Taylor series" is just what Filip Larsen says, but you can also do what you were trying- you just stopped too soon. Since
\frac{-5x+ 4}{16x+ 20}
has the same order in numerator and denominator you could also divide that. In fact,
\frac{x^2+ 1}{4x+ 5}= \frac{x}{4}- \frac{5}{16}+ \frac{11}{16}\frac{1}{4x+ 5}
Now, what you can do is write that last fraction as
\frac{1}{5- (-4x)}= \frac{1}{5}\left(\frac{1}{1- \frac{-4x}{5}}\right)}
Recall that the sum of a geometric series is given by
\sum_{n=0}^\infty r^n= \frac{1}{1- r}
so that can be written as a power series in
\frac{-4x}{5}
Neat. I guess that would "correspond" to Taylor series evolved around x0 = 0 and with -1 < x < 1. Is is possible to make something equally neat for x outside this range, or are you then "stuck" with the general Taylor series?
  • · Replies 27 ·
  • · Replies 105 ·
