Find Taylor Series for 1/x Around x=3
The discussion focuses on finding the Taylor Series for the function f(x) = 1/x centered at x = 3. The derivatives calculated include f'(x) = -x^-2, f''(x) = 2x^-3, f'''(x) = -6x^-4, and f''''(x) = 24x^-5. The correct Taylor series expansion involves evaluating the derivatives at the center point, specifically f^{(n)}(3), rather than f^{(n)}(x). The user initially misrepresented the series sum, which should be corrected to reflect the proper coefficients derived from the derivatives evaluated at x = 3.
  • Understanding of Taylor Series and their applications
  • Knowledge of calculus, specifically differentiation
  • Familiarity with evaluating functions and their derivatives at specific points
  • Basic algebraic manipulation skills
  • Review the derivation of Taylor Series for different functions
  • Learn how to compute higher-order derivatives effectively
  • Practice evaluating derivatives at specific points, such as f^{(n)}(3)
  • Explore the convergence of Taylor Series and their radius of convergence
Students studying calculus, particularly those focusing on series expansions, as well as educators teaching Taylor Series concepts and applications.
soitgoes2019
Find the Taylor Series for f(x)=1/x about a center of 3.
f'(x)=-x^-2
f''(x)=2x^-3
f'''(x)=-6x^-4
f''''(x)=24x^-5
f^n(x)=-1^n * (x)^-(n+1) * (x-3)^n
I'm not sure where I went wrong...
How did you write the sum, i.e. the requested Taylor series? And what is wrong or why do you think it is wrong?
I wrote the sum from n=0 to ∞ as: ∑-1^n (x)^-(n+1) (x-3)^n
I'm not sure if that is correctly centered at 3
As far as I can see, there is only a minor error; however crucial to the usage of Taylor series. You should check the general formula again.
Edit: And your formula for ##f^{(n)}## is wrong. You must not drop the coefficients all of a sudden, only because they might cancel out later in the calculation.
f'(x)=-x^-2
f''(x)=2x^-3
f'''(x)=-6x^-4
f''''(x)=24x^-5
When you expand ##f(x)## about ##x = 3## your coefficients involve ##f^{(n)}(3)##, not ##f^{(n)}(x)##. But, of course, you compute ##f^{(n)}(3)## by first computing ##f^{(n)}(x)## and then setting ##x = 3##.
  • · Replies 27 ·
