Technical Analysis on Titan Sub (Titanic Sub)
  • Thread starter Thread starter hagopbul
    Acoustics
276 replies · 27K views
There is a youtube video dated Oct. 19, 2023 and a comment by an aeronautical engineer about carbon fiber construction.
The comment is #2005 by @airas, at the top of the comment list as of this post.
The claim is faulty lay-up of the Carbon fiber during construction. Looks plausible.
Cheers,
Tom
Reply
Excellent video.
I disagree with the idea that one must test to destruction. (Although one could argue that's what this dive was) It is often impractical, and evem the US Navy doesn;t do this. I also question what would have been learned - if the first dive had 50% margin, wouldn't they have said "Great! Now we know we have no problem!"
I know little about winding CF, but a little about winding SC magnets, Now that I have, albeit briefly, seen how this is wound, I'd be worried about torsion. If the layers aren't perfectly straight, this will turn the water pressure into a twist.
Reply
Neither does the FAA. Transport category aircraft have a design limit load factor of 2.5 without significant damage, and ultimate load factor of 3.75 without catastrophic failure. They do a static test, and if it passes, it's strong enough. This is a photo of the Boeing 787 wing static test. If you are ever in one of those airplanes in severe turbulence, now you know how far the wings can flex.
Reply
  • Wow
I cannot get my head around the compressive strength of tensile fibres. It seems to me that the compressive strength comes from the epoxy binder, and that the fibres reduce that section.
All fibres in that layup are running in the plane of the cylindrical surface, none are radial. Radial fibres are needed to prevent spalling or delamination of the epoxy under compression.
So why are the fibres there? Would it not be stronger if the CF was replaced with epoxy?
I would expect better results if the pressure hull was cast with epoxy, loaded with short randomly oriented Kevlar or CF designed to prevent delamination.
Reply
777 though:
There is a cabin in the way.
The radial forces are transferred to the collar of the hemispheres and to some degree the hoop fibers.
And epoxy is strong stuff as well.
The fibres used should have the same temperature coefficient, young's modulus, and speed of sound as the epoxy filler.
The radial fibres should cross the wall, stitching the layers together, to prevent delamination.
Then why use the carbon fibre in a compressive orientation. It would be better to avoid the fibre which will progressively delaminate if the temperature coefficient, modulus of elasticity, or speed of sound are different to the epoxy.
It may not look it, but tensile strength is critical. Compression is not the whole story.
The problem is not that the hull might evenly shrink under pressure, killing the passengers. The problem is that it might buckle. That has compression on one side and tension on the other.
This is why the US Navy uses high tensile strength steel for its submarines. They have not lost a submarine in over 50 years, even after driving at least one into a mountain.
I used a unidirectional carbon fiber rod in an application where we needed light weight, high stiffness, and Euler buckling for overload. Since a design review raised concern about it breaking when buckling, I ran a test. A 15" length of rod needed to buckle sideways about 3", and it did not fail until bent far enough that the free ends almost touched. It failed in tension. The failure was a sudden brittle fracture with a loud noise and pieces flying across the room. The test was repeated several times, and each failure was on the tension side. The tensile failure was interesting because the specifications for the rod call for it to be stronger in tension than compression:
The rated compressive strength of the rod is almost two orders of magnitude larger than the compressive strength of epoxy. I believe the compressive force are supported by the fibers, while the epoxy prevents local buckling of the fibers.
Since we needed to convince a number of people, we made a video of the test. I knew that it would shatter, so was wearing goggles and heavy leather gloves. I did not realize that I was standing under a bright light that made me look like some sort of demented mad scientist on the video. Several years later, that video was still being shown to new engineers, apparently to warn them about the guy in that office over there.
Reply
  • Haha
Any way you can share the video, or at least a still frame?
Reply
Oh, come on. Now that you've shared that it happened, you HAVE to show us so that we can warn the newbies about the monster in our midst. :oldlaugh: :biggrin::oldsurprised:
Reply
The tension that prevents buckling under external pressure is circumferential, on the inside of the cylinder.
That inner layer has been pre-compressed and shortened by hydrostatic pressure from outside the vessel, which is not helping to increase tension in the inner layer to prevent inward buckling.
When tension is applied to the inner hoop, that inner surface would tend to be pulled away from the concave neutral layer. I would expect any inner tension to result in a further crushing of the outer hoop layers that are then under greater load, with a delamination of the inner layers, and a failure to prevent the buckling.
Since any inner layer hoop tension must be countered by outer layer hoop compression, I see no advantage in relying on tension to prevent inward buckling of external pressure vessels.
phinds said:
Paywall
I got in without paying.
Wired said:
IT WAS TIME for the engineers to hand it over to OceanGate’s operations team for testing at sea. But there was another snag. David Lochridge, who oversaw marine operations at the company and who needed to sign off on the transfer, became convinced that Titan was unsafe. In January 2018, Lochridge sent Rush a quality-control inspection report detailing 27 issues with the vehicle, from questionable O-ring seals on the domes and missing bolts to flammable materials and more concerns about its carbon-fiber hull. Rush fired him the next day. (Although Lochridge later made a whistleblower report to the Occupational Safety and Health Administration about Titan, Rush sued him for breach of contract. The settlement of that lawsuit resulted in Lochridge dropping his complaint, paying OceanGate nearly $10,000, and signing an NDA. Lochridge did not respond to WIRED.)
Several former employees said they were neither shocked nor surprised at OceanGate’s deadly accident. Three had left the company on safety grounds, and two separately described Titan as a ticking time bomb.
Don't like what the engineers say? Fire them and then sue them if they mention it, even if they did it via proper channels. Another example of science and business by litigation. Disgusting that Lochridge lost the case.
Reply
  • Wow
  • Sad
NDAs should not override considerations of safety or law. Unfortunately, that is the world we live in.
Reply
The Juice Media, on Australian Whistle Blower Legislation.
Reply
  • Love
  • Haha
I had to read that a few times. Sounds like a case of "rich guy has better lawyers" rather than justice.
Where I worked, we were required by law to report unsafe conditions to the feds if our company didn't address safety concerns to our satisfaction.
Reply
Seen that attitude, and not just once.... This guy just had more money, bigger say in the company - and more victims....
Reply
Log of “Titan” Sub Crew’s Final Words Deemed Fake, Investigation Finds: Report
https://news.yahoo.com/news/log-titan-sub-crew-final-171107867.html
A purported log of the Titan submersible crew's final words has reportedly been deemed fake.
A federal team of investigators “found no evidence” that the five people onboard the Titan sub on June 18, 2023 were aware of the pending implosion, according to The New York Times.
The transcript, which began circulating online just days after the submersible went missing in the Atlantic Ocean, offered a detailed timeline of the supposed events and conversations leading up to the implosion.
“I’m confident it’s a false transcript,” said Captain Jason Neubauer, a retired member of the U.S. Coast Guard who serves as chairman of the Marine Board of Investigation. “It was made up.”
federal investigators obtained records of the real communications between the submersible and the Polar Prince, which apparently disprove the viral transcript’s accuracy.
“Somebody did it well enough to make it look plausible,” Neubauer said.
James Cameron reveals devastating intelligence he received about doomed Titan submersible after disaster
https://www.independent.co.uk/news/...bmersible-titanic-investigation-b2560428.html
James Cameron Says Titan Sub Mission Shouldn't Have Been Allowed: They 'Broke The Rules'
https://www.yahoo.com/news/james-cameron-says-titan-sub-102608398.html
Reply
I find it interesting that engineers who warned of trouble don't want to be named, lest they be sued. I guess for being "insufficiently convincing".
A $50m Lawsuit and a disturbing claim that the crew knew they were going to die.
"When the acoustic safety system’s alarm sounded, signaling the hull was “cracking under extreme pressure,” it prompted the pilot to release weight and attempt to abort the expedition.
The crew had no communications and likely would have had no power either. “Common sense dictates that the crew were well aware they were going to die, before dying,” the suit states."
https://www.independent.co.uk/news/...mersible-wrongful-death-lawsuit-b2592900.html
Reply
Some footages were released about the crushed vehicle laying on the ocean floor.
Also, the official transcript of the dive communication is available now.
Youtube is full of the stuff, so I think linking would be just unnecessary.
Ps.: the Coast Guard official hearings (was this month 16., 17., 19. so far) are available on their official YT channel, if anybody interested.
Linking to something specific accomplishes at least two things:
  1. The poster presumably has vetted the Youtube stuff and chosen good content, weeding out the bunk, and
  2. We can all reference - and talk about - the same segments.
Reply
DaveC426913 said:
presumably .... weeding out the bunk
I could not find either the original release nor a worthy secondary source, so with just a notice I left it for the participants to start picking by their own interest.
Reply
There is two weeks of the hearing to go, the BBC summarises here. Some footage and also the last text messages which give no indication of anything amiss.
Reply
See the EDIT below.
Could you verify/correct that youtube link?
youtube does not recognize that link, a youtube search shows "not found."
Google returns something in Russian.
:oldcry:
[EDIT] It showed up in this post as a playing image; yet your post (and all previous youtube links) shows up as a white triangle inside a Red rectangle!
[EDIT 2] Now, this post is back to White triangle inside Red rectangle.
Curiouser and Curiouser.
I suspect the poldergeists & gremlins are playing with us!
[EDIT 3] Arrrgh! A screen refresh turns youtube links back to the triangle/rectangle. I think I'll give up trying to understand it. :cry:
The failure to communicate distress by voice, may be influenced by the early ingress of salt water into the electronics. Initial revelations will be carefully controlled to protect those involved.
We will need to wait for the end of the inquiry, in a couple of weeks, before anything reliable and significant appears.
