Tell me the fourmla for displacement
  • Thread starter Thread starter killer22
    Displacement
3 replies · 3K views
killer22
okay i have a question.
if a squirrel is at 0 on inital velocity and then is at -2 at final velocity.then what is its displacement?
And i would appreciate it if someone can tell me the fourmla for displacement.:smile:
you need to give a lot more info to be able to do this problem
disp= x_o+v_0*t+1/2at^2
I think you would have a negative displacement you instead of going forwards went backwards your displacement would be 2. I think I have problems with physics so...
Like mathmike said, you need to give a lot more information so an accurate displacement can be given, unless you are searching for displacement as a function of acceleration/time etc.
Using:
[tex]s=ut+\frac{1}{2}at^{2}[/tex] (1)
or
[tex]v^{2}=u^{2}+2as[/tex]
Hence, [tex]s=\frac{v^{2}-u^{2}}{2a}[/tex] (2)
where,
s=displacement
u=initial velocity
t=time
a=acceleration
Using the information you have given, formula (1) can be simplified to:
[tex]s=\frac{1}{2}at^{2}[/tex]
and formula (2) can be simplified to:
[tex]s=\frac{2}{a}[/tex]
It is obvious you will at least need acceleration to find the displacement, and yes, the displacement will be negative since your final velocity (v) is negative.
