Temperature and Electrical Potential
In summary, the plasma potential is the potential energy that exists between any two particles in the plasma. The temperature of a plasma is the thermal energy of these particles. Higher plasma temperatures have higher plasma potentials. This is due to the separation of electrons and positive charges, which causes a local potential field.
gareth
189
Hi,
I posted this in General but to no avail, any ideas?
Hi,
Hope I'm in the right place for this question,
I am currently studying the basic properties of a plasma and I've come to the understanding that the plasma potential is the potential energy that exists between any two particles in the plasma (electrons).
Also I have found that hotter plasmas have a higher plasma potential.
(please correct me here)
Is this because that in a hotter plasma the electrons will be closer together and hence have higher potential?
If not, what is the relation between plasma electron temperatures and plasma potentials?
Thanks
Gareth
Plasma temperature does not depend on the distance between charged particles.
Very hot plasma with low density of charged particles can be obtained, and high-density cold plasma can be obtained too.
Thanks Miknsk,
Then why is the plasma potential strongly linked to the plasma temperature?
Electron mobility is related to temperature (temperature is a measure of average kinetic energy) and the electrons are more easily separated from positive charges as temperature increases. One site mentioned electrons moving out of a plasma to the metal containment, such that the plasma develops a net positive charge while the container develops a net negative charge. This would then cause the plasma (+ ions) to drift (expand) toward the negative charged container.
Plasmas try to maintain charge neutrality.
See - http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/kintem.html
Thanks Astronuc
So hotter electrons,
1) are more mobile
2) reach the containment wall faster
3) cause a positive charge to build up in the plasma (plasma potential)
and hence a higher electron temperature causes a higher plasma potential
However, should the flux of ions to the surface not also increase as the plasma temperature increases? This would cause all plasma potentials to be the same would it not?
It's the separation of charges that causes local potential field. The plasma and metal container are good conductors, so any electrons leaving a confined plasma and making it to the containment would spread out very quickly. The plasma then has a net positive charge (because they are not balanced by the absent electrons) and that's distributed primarily at the surface.
Is the question primarily about confined plasmas? Astrophyiscal (e.g. stellar) plasmas on a much larger scale are much more complicated.
gareth said:
Thanks Astronuc
1) are more mobile
Plasma potential acts as potential barrier for electrons confined in plasma. So what will happen if the electron energy is suddenly arisen, for example, by an order of magnitude?
Electrons will overcome the potential barrier and negative charge located on the walls will increase rapidly, so the plasma potential should increase too till it stops electrons.
I think, it will happen when the plasma potential is arisen by an order of magnitude too.
Astronuc,
Yes it a question regarding confined plasmas, in particular, flowing plasmas diagnosed with a Langmuir probe.
So I supose in this case the probe (metal tip) acts as the containment, which, when confronted by the plasma absorbs electrons, when the potential in the plasma (caused by the depletion of the electrons) is strong enough to hold the electrons in the plasma we have arrived at the plasma potential.
So, the idea of plasma potential only really exists in contained plasmas, in space for example, would their generally speaking, be an overall charge neutrality in the plasma?
Or do electrons manage to escape because of their kinetic energy?
Any thoughts on this folks?
Just to re-iterate, if a plasma expanding in free space, does it reach a plasma potential? I.e do some of the electrons just escape because of their kinetic energies and keep on going with their thermal energy converted into translational kinetic energy?
Thanks
What is the relationship between temperature and electrical potential?
The relationship between temperature and electrical potential is complex and varies depending on the material and conditions. In general, an increase in temperature can lead to an increase in electrical potential, but there are many factors that can influence this relationship.
How does temperature affect the conductivity of materials?
Temperature can have a significant impact on the conductivity of materials. In most cases, higher temperatures lead to increased conductivity as the atoms and molecules in the material have more energy to move and carry electric charge. However, there are some materials that exhibit the opposite effect, where their conductivity decreases with increasing temperature.
What is the Seebeck effect and how does it relate to temperature and electrical potential?
The Seebeck effect is the phenomenon where a temperature difference between two materials causes a flow of electrons, resulting in an electrical potential. This effect is used in thermocouples to measure temperature and is closely related to the relationship between temperature and electrical potential.
Can temperature affect the voltage output of a battery?
Yes, temperature can have a significant impact on the voltage output of a battery. In general, higher temperatures can lead to a decrease in the voltage output of a battery, while lower temperatures can increase it. This is because temperature affects the chemical reactions that occur within the battery, which in turn affects its voltage output.
How does temperature impact the accuracy of temperature and electrical potential measurements?
The accuracy of temperature and electrical potential measurements can be affected by temperature in several ways. For example, changes in temperature can cause thermal expansion or contraction of materials, leading to changes in their electrical properties. Additionally, temperature fluctuations can introduce noise into the measurements, making it more challenging to obtain precise and accurate readings.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • Nuclear Engineering
  • High Energy, Nuclear, Particle Physics
  • STEM Academic Advising
