Temperature coefficient of resistance calculation
8 replies · 12K views · last reply
Preksha
When we are supposed to calculate the value of "temperature coefficient of resistance " i.e. α , how are we supposed to choose between the following two formulae :
α = (R2 - R1) / (R1*T2 - R2* T1 )
or
α = (R2 - R1)/ [ R1 *( T2-T1) ]
I have attached scanned pictures of two similar questions . I can't understand as to why diff. formulae are being used in both of them
  • Printed textbook page showing Example 43: resistance of a conductor at 20°C and 100°C, solved by dividing R1 = R0(1 + αt1) by R2 = R0(1 + αt2) to give α = (R2 − R1)/(R1t2 − R2t1), with t1 = 20°C, R1 = 3.15 Ω, t2 = 100°C, R2 = 3.75 Ω.
  • Printed textbook page showing Example 47: a metal wire of diameter 2 mm and length 100 m, resistance 0.5475 Ω at 20°C and 0.805 Ω at 150°C, with the temperature coefficient of resistance calculation alpha = (R2 - R1)/(R1(t2 - t1)) = (0.805 - 0.5475)/(0.5475(150 - 20)) = 3.6 × 10⁻³ °C⁻¹.
I am new to this forum, so I have no idea as to how things work here. I wanted to know, till when , can I expect a reply to my question?
Its not a linear function.
http://img405.imageshack.us/img405/9383/co3wv.jpg
Ratch said:
Preksha,
My physics book agrees with this link, which is a different formula than what you submitted.
Ratch
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/restmp.html
My second formula is the same as yours.
The first one can be derived as
R1 = R0(1 + aT1) ...(i)
R2 = Ro (1 +aT2)... (ii)
Divide (i) by (ii)
And you'll get the 1st formula.
Both formulae are correct.
The difference in their usage is that When T1 is 0deg. The 1st formula changes to the second one. But when I came across this particular question where T1 =20 deg (the one I've posted before) and still they are using the second formula, i got thoroughly confused. So, if you have any idea, please help.
I didnt get you :O How does linearity play a role in this question?
Preksha,
or
Use the one that is correct. The second formula agrees with the link I posted, so use that. The first formula can be arranged to R=Ro(1+αT)/(1+α*To). Does that make sense compared to the first formula, which is R=Ro(1+α(T-To))?
Yes, that is the correct one.
Divide (i) by (ii)
Your derivation is wrong. R1 = Ro(1+α(T1-To))
They both can't be correct.
In order for the formula to be correct, it must be correct across the whole temp range, not just one temperature. Use the one proven to be correct.
Ratch
Hello Preksha. Welcome to PF !
Be patient. While you're waiting, read the rules for this Forum, particularly the section regarding Homework Help.
Rules
