Temperature of fluid flowing through pipe
178 replies · 45K views · last reply
Jay_
Is there a mathematical relation for the temperature change when a fluid flows through a pipe from one end to another?
I am not aware of any equation in thermodynamics for this, but I would guess the following parameters are important :
1. cross-sectional diameter of pipe
2. viscosity
3. volumetric flow rate
4. specific heat of the fluid
5. length of pipe.
2. viscosity
5. length of pipe.
Yes, and you've identified all the parameters involved, except for the density and thermal conductivity of the fluid. See any book on transport processes or heat transfer. I highly recommend Transport Phenomena by Bird, Stewart, and Lightfoot.
This site has temperature analysis of pipe flow:
http://sites.google.com/site/vortextubeeffect/vortex-tube-rectilinear-motion/
the pipe could be stationary or moving.
The following site has a summary of what you are looking for for both laminar flow and turbulent flow in at tube in which the wall temperature is constant along the tube: http://web2.clarkson.edu/projects/subramanian/ch302/notes/Convective%20Heat%20Transfer%201.pdf
2. viscosity
5. length of pipe.
Don't forget the temperature (and thermal properties) of the pipe itself.
Chestermiller
That pdf defines a number of constants for the fluid flow, but it doesn't give a more direct mathematical relation.
What I am trying to find is :
ΔTemperature = f(parameters)
Thank you.
Sunfire
Your link seems to say a frame of reference is important? The equation I need is for temperature from a exhaust pipe of a car (for instance), and the radiator hose.
The equations in the page seem to show that the temperature is only dependent on velocity and specific heat of the fluid. I imagine more factors are invovled.
Thank you.
Andy Resnick
Yes, the thermal properties of the pipe are important too. I am trying to get this equation for the exhaust pipe of a car and the radiator hose.
Hi,
you are most certainly right. The quoted page gives ΔT when the pipe velocity equals c and the flow exit absolute velocity is also c. This is the maximum cooling that can happen, assuming that both velocities match. This is the simplest case.
To fully understand how the entire phenomenon happens, you will need to approach it methodically.
1) You have to read about "Fanno flow" in a stationary pipe. Fanno flow analysis will tell you how the flow exit velocity depends on the friction factor and the length of the duct etc.
This is for motionless duct.
2) Once you know the exit flow velocity (from Fanno flow analysis), go back to the page and apply the temperature analysis with your particular parameters.
3) This will give you the ΔT you are looking for.
I hope this helped!:smile:
Jay_ said:
Chestermiller
Thank you.
Sunfire
Thank you.
Andy Resnick
If this is what you are trying to do, then the problem is much more complicated than just a simple explicit equation for the temperature change as a function of the parameters. Sorry.
For your situations, you are going to have heat transfer resistance within the pipe, heat transfer resistance through the pipe wall (as AR indicated), and heat transfer resistance on the outside of the pipe. In addition, for the exhaust pipe, radiative heat transfer (both inside- and outside the pipe) is probably going to be significant (and needs to be taken into account). The radiator is going to have cooling fins, and that is going to be important. You just need to learn heat transfer, or hire a heat transfer consultant. There is too much material to cover to present all this here. If you want complete coverage see Transport Phenomena by Bird, Stewart, and Lightfoot, or Heat Transmission by McAdams.
Chet
Do the books you mention describe the phenomenon in detail? Because I would only purchase them if they are useful in that aspect. Which one of the two books would you recommend?
Yes. Both books do. Bird et al is a great book no matter what your motivation. it's a classic that was updated in ~2000 with the 2nd Edition. This is the one book that I used during my 40 year professional career more than all the others combined.
Chet
Thanks Chestermiller, I got the book. Could you tell me which chapters are relevant for me to find the equation I am looking for?
Chapters 10 - 16, particularly Chapter 14 and possibly chapter 16 (if radiation transport is important).
Hi,
I am not sure which equation actually refers to this. In any case, I am actually obtaining the temperature as data using sensors in my project.
But I still need another equation :biggrin: :smile:
The equation for either the Power or Energy given off by such a fluid when its temperature has risen by ΔT.
My immediate guess is Q = mcΔT which I learned in school. But would it be correct to use this equation for the radiator hose and exhaust, which have fluids in motion?
Thanks.
I found the equation I was looking for. Its 14.6-1 to 3 in the book. I might be coming back here for some help though again. Thanks
Hey Chestermiller,
Could you tell me why would the equation for temperature difference be related to energy and not power (energy per unit time)?
In my case here, I have a fluid that is constantly being heated up (by the engine), so would there be a corresponding equation for heat POWER instead of heat ENERGY?
Jay_ said:
Hey Chestermiller,
The engine power is only a fraction of the rate of energy from burning the fuel. Much of that energy goes out the exhaust, and, if you don't cool the engine by the radiator, you will be very unhappy. The amount of heat removed by the radiator is not equal to the engine power.
Rate of Energy released by burning fuel = (engine power)+ (rate of heat out exhaust)+(rate of heat out radiator)...roughtly
Thats right.
What I am doing is measuring the temperature of the heated fluid coming out of the exhaust and through the radiator. But temperature is not the same as heat, so that's why the search for the equation that correlates temperature to rate of heat energy through these (heat power).
This is far off what I have studied in physics. Thank you for helping me. I am still reading Bird's book, didn't find anything on this though.
Hi Chestermiller,
Two equations for rate of heat energy are present in the pdf attached. In the topic IV, Heat Exchanger Subsystem do equations (2) and (3) give us the same quantity expressed as a function of different constants?
I would be using equation (3) but is the Qa for equation (2) a different one, or the same?
Jay_ said:
Hi Chestermiller,
In my judgement, these equations are not adequate for what you are trying to do. You should first take a step backwards, and just try to model the radiator as a heat exchanger. You can measure the water flow through the radiator, and you can measure the water temperatures in and out. You can also estimate or measure the rate of air flow across the radiator tubes, and the temperature of the air before it hits the radiator. Then you can use the information in BSL to estimate the heat transfer coefficient for the radiator, and determine whether this is consistent with the observed change in the water temperature. Once your model of the radiator is predictive, you can work your way back into the engine, to consider the heat transfer from the engine metal to the water circulating through the engine block. To do the engine, you would have to include the heat given up in combustion of the fuel/air mixture, and the work done by the expanding gas on the pistons. Maybe you can find a book on automotive engineering to help you analyze these things.
I feel like, if your goal is to model the entire fuel system and cooling system, you may have underestimated the complexity of the problem, and you are going to have to develop a lot of fundamental background before you can do this.
Chet
Sorry for the late reply Chestermiller.
Right now, I want to just deal with the energy wasted through the exhaust (not the radiator).
The temperature sensor I have can only detect the heat at the outside of the pipe. I don't have a sensor that can be put inside the starting of the exhaust. Due to that I was hoping to make use of equation (3) { Qa = hAΔT } to make an estimation of the energy.
What I had in mind was placing one temperature sensor at the beginning and another at the end (both outside the pipe) to get a temperature measurements. And then using those to calculate the rate of heat energy.
So what's the best way to do this given the type of sensors that can't come in direct contact with the gas itself?
Jay_ said:
Hi Chestermiller,
The two equations must match up when you eliminate the Qa's.
It's supposed to be the same.
Chet
Chestermiller, I really really appreciate your help. The thing is I am not able to communicate effectively with the professor who is supposed to be helping me through this. At the same time, its pretty late to be changing what I am doing and he always seems busy to respond.
1. If Qa is the same in equation (2) and (3) I assume I can use anyone of them to estimate the rate of heat energy.
2. When I discussed things with him last, he mentioned to me that just one temperature sensor at the beginning of the exhaust pipe is good to estimate the energy of the gas. Now this equation in this page is same as equation (3) I believe :
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/heatra.html#c2
If my sensor is outside the pipe, I would only obtain T_cold, how can I estimate the rate of energy change without knowing T_hot?
If I recall correctly, you are trying to determine the amount of energy exiting the engine and entering the exhaust pipe.
Your professor is correct. The rate of energy loss in the gas stream entering the exhaust pipe is wCp(Tbeginning-Tref), where w is the mass rate of flow through the pipe, Cp is the heat capacity of the gas, and Tref is the reference temperature from which enthalpy of the gas stream is calculated.
The equations you are using are trying to estimate the heat loss between the entrance and exit of the exhaust pipe. But this is not what you are interested in determining. You are interested in determining the rate at which energy enters the exhaust pipe.
Chet
Yes sir, that is right.
Wouldn't I need another sensor to calculate w (mass flow rate)? I was hoping to use equation (3) because it uses constants belonging to the pipe which I can obtain easily I think.
Given that I have my temperature sensor outside the pipe at the beginning of the exhaust, is my temperature sensor sensing Tbeginning or Tref?
Hi Jay,
This is an engine, and you are trying to determine the energy losses from the engine. Is this correct?
If so, here are some questions:
Are you a chemical engineer, an automotive engineer, a mechanical engineer, or a physicist?
What year are you in at school?
Have you had a course in Thermo yet?
What is the rate at which gasoline is consumed?
What is the air/fuel mass flow ratio?
How does the mass flow rate of gases exiting the exhaust pipe compare with the mass flow rate of fuel and air supplied to the engine? Does this give you a hint as to how to determine w?
If you have had Thermo, have you learned about enthalpy, heat of reaction, and heat of formation?
Do you know the composition of the gases in the exhaust?
Do you know the coolant flow rate to the radiator, and the temperature change of the coolant in passing through the radiator?
Chet
I am electrical and this is far from what I have dealt with. I have mostly done programming and basic electrical circuits but never dealt with a car before. The car being used is a Honda Accord I think.
Just through the exhaust would be good for now.
The thing is I am capturing everything in real time - the speed using the hall sensor, the temperature of the outside of the pipe using the temperature sensor. These are the only two things I have as of now. And they get saved into text files (from the COM port of my laptop) as they are being captured. Do I need to do the same for any other parameter like mass flow rate? My professor asks me to find the equation but I can't find any equation which allows me to estimate the energy coming from the exhaust by merely knowing the temperature of the outside of the exhaust pipe.
My question is do I need another sensor (to measure another varying parameter) to estimate the energy coming into the exhaust?
I have studied enthalpy, heat of reaction and heat of formation at a theoretical level. But the issue is capturing all this in real time and having the data values logged. I don't know the composition of the gases in the exhaust, but I don't think finding that would be too hard.
Thanks for your help Chet.
I'm a little confused as to what you are trying to determine. There are two possibilities:
1. The amount of heat lost through the wall of the exhaust pipe into surrounding air
2. The amount of heat contained in the gas entering the exhaust manifold.
Heat contained in the entering gas is a relative quantity, and depends on what datum is used for the initial state. Heat lost through the wall is equal to the change in enthalpy between the inlet and exit of the pipe.
To get the heat contained in the entering gas to the manifold, you need to know the flow rate of the gas, its temperature, and its composition. You also need to know the datum for the calculation, such as the enthalpy of the air and the fuel fed to the engine.
To get the heat lost through the wall of the exhaust pipe, you need to know the average gas temperature and the heat transfer coefficient (Eqn. 3), or you need to know the inlet temperature, the outlet temperature, the gas flow rate, and the gas composition (which determines its heat capacity) (Eqn. 2). You can also get what you want if you know the inlet temperature, the heat transfer coefficient, the gas flow rate, and the gas composition (Combination of Eqns. 2 and 3). So, it isn't clear what you need to measure, and what you can calculate. The hard part is estimating the heat transfer coefficient. The easiest thing is to measure the temperatures at the inlet and the outlet, and use the (known) gas flow rate and estimated heat capacity to get the heat loss.
So, it isn't clear what your professor wants or expects. Do he even know?
Chet
Its 2. that I actually want.
If I understand correctly, its impossible to find 2. with just a temperature sensor placed outside the exhaust pipe. Its only possible to find the heat of equation 3. with TWO temperature sensors too. Would these statements be accurate?
I am presently on search of a holy-grail-like equation which is supposed to give me 2 (heat contained in the gas) with just a temperature measurement made of the outside surface of the exhaust pipe.
What sensor could I use for that? Would you have any idea sir? I was thinking of using a exhaust gas temperature gauge but I need to find one that can be interfaced with my Arduino board.
Heat contained in a stream is a relative quantity, so you need to define "relative to what." You might define it relative to the unburned gasoline and air fed to the engine. If you only want the heat per unit mass, then you need to know the temperature of the gas entering the exhaust manifold and its composition. If you want to know the rate of heat exiting, you also need to know its mass flow rate.
It's not going to happen.
This is not my area of expertise.
Chet
Thanks Chet. That clears a lot. I will speak to him soon and if I have any questions in regard to this I will post here again.
You have been of great help. I really appreciate it.
