What is the correct way to find the temperature of helium in this scenario?
  • Thread starter Thread starter Angelina21
    Helium Temperature
The correct method to find the temperature of helium in a pressure vessel involves using the ideal gas law, specifically the equation PV = nRT. In this scenario, the pressure is 5.42 bar, the density is 0.92 kg/m³, and the gas constant R is 8.314 J/(mol*K). The initial attempt incorrectly substituted the number of moles with density, leading to an erroneous temperature calculation of 70000 K. The solution requires expressing the number of moles in terms of the known properties of helium.
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of gas constants and their units
  • Familiarity with density and its relationship to moles
  • Basic algebra for manipulating equations
  • Review the ideal gas law and its applications in thermodynamics
  • Learn about the properties of helium, including its molar mass
  • Study how to convert between density and number of moles
  • Explore common mistakes in gas law calculations and how to avoid them
Students studying thermodynamics, physics enthusiasts, and anyone needing to solve problems related to gas laws and properties of gases.
Angelina21
Helium is kept in a pressure vessel at a pressure of 5.42 bar and the resulting density is 0.92 kg/m3. The gas constant R is 8.314 J/(mol*K). The volume of the vessel is 1589.194 m3. I need to find the temperature of helium in Celsius.
pressure(Pa)=density(kg/m3)*R*temperature(K)
With the formula given, I got the answer of 70000 K which is logically not correct.
Hi Angelina21,
Welcome to Physics Forums!
PV = nRT
You can't simply replace n (number of moles) with density. Try expressing n in terms of things you know about helium in general and the helium in this case.
gneill said:
Hi Angelina21,
PV = nRT
I think I got the answer now. My formula was indeed wrong. Thanks!
10K
