Temperature on the outer surface of insulation
The discussion focuses on determining the outer surface temperature of insulation on pipes, specifically addressing the influence of insulation thickness and heat transfer rates. Participants emphasize that pipe designers calculate insulation thickness based on desired heat flow rates and required R/U values rather than specific surface temperatures. A rule of thumb is provided, indicating that for a 1°F temperature difference at the surface, the insulation R value must be at least 182, translating to approximately 45.5 inches of fiberglass batting for effective insulation. The conversation also highlights the importance of convection effects and the use of insulation calculators for practical applications.
  • Understanding of thermal conductivity and resistance (K and R values)
  • Familiarity with heat transfer principles, including conduction and convection
  • Knowledge of insulation materials and their properties, specifically fiberglass batting
  • Basic proficiency in using insulation calculators for thermal analysis
  • Research the use of insulation calculators for thermal performance evaluation
  • Learn about the principles of heat transfer, focusing on conduction and convection
  • Explore different insulation materials and their R values for various applications
  • Investigate real-world case studies on pipe insulation design and thermal management
Engineers, HVAC professionals, and anyone involved in thermal insulation design and analysis will benefit from this discussion, particularly those focused on optimizing insulation for piping systems.
anolan23
This seems basic, but I'm stuck.
Look at the attached picture. I'm trying to find the temperature on the outer surface of the insulation. Is it not possible because I do not know the rate of heat transfer? How do pipe designers know the required thickness of insulation needed to reduce to a desired surface temp?
Ambient is 32F
http://imgur.com/a/TJmxO
Likes Cbergeron
The outer surface temperature is approximately ambient.
I know it goes hot to cold, but I'm pretty sure the -150F has an influence on the outer temp.
Likes Cbergeron
The outer surface cannot be ambient. There will be some conduction through the insulation to the outer surface based off the large difference in temperature.
Likes anolan23
You need to know the heat transfer coefficient between the surface and the ambient. This may be the result of natural convection and forced convection.
No, but it can be approximately ambient...and that assumption is reasonable for any significant amount of insulation...just as the inside surface temp is approximately equal to the pipe fluid temp.
Pipe designers don't design to a particular surface temp, they design to a particular heat flow rate and then decide on an insulation R/U value required to achieve it.
Likes Chestermiller
If the insulation was a few feet thick, then yes id assume it was approximately ambient. What if the insulation is only 2mm thick? I'd expect the temperature to be much less than 32F ambient.
Likes Cbergeron
Sure, if it is 2mm that assumption would not hold...but who ever uses 2mm thick insulation? So I guess the real question is: what is the context and rest of your question? Homework? Exam? Your OP appeared to be asking about real-world, but you didn't post the entire problem and it doesn't look to me to be real-world.
FYI, I quickly found an insulation calculator via google and found that for your problem and some real-world assumptions about typical insulation type/thickness, the surface temperature was further off than I expected. I was expecting just a couple of percent, but it was more like 8%. For real-world engineering that is plenty close enough for this problem, but again, I don't know what your needs are.
edit:
Also, before I googled for the calculator I poured myself a cup of coffee and was concerned enough about what I felt that I did a quick calc, which then prompted the search for more info. Point being, this issue is really easy to test.
Thanks for your help. I'm trying to find how much thickness 'till we can approximate 32F.
I know convection on the outer surface matters.
How "approximate" are you willing to accept? And to what level of rigor do you want to do the problem(is an online calculator ok?)? Is this real-world?
To 1 Degree Fahrenheit. online calculator is fine.
I calculated the Qrate to be 340W, but that is assuming 1.5 inches.
http://imgur.com/a/HyIOF
I want to calculate the thickness needed to reach 32F from purely conduction
Ambient is 32F
I'm used to doing it in R=BTU/Hr/ SqFt/ °F. Here goes.
  • Rule of Thumb: Most surfaces in free air have an 'R' value of 1. Exception: Metal and Glass surfaces are half that.
  • You want external surface within 1°F of 32°F
  • For 1°F Temp difference at the surface you can have no more than 1BTU/Hr/Ft2
  • the Temperature difference is 150+32 = 182°F
  • ∴Insulation 'R' value ≥ 182
  • 3" of fiberglass batting is around R12, or R4 per inch (If I remember correctly)
  • ∴Insulation thickness is 182/4 = 45.5 inches of fiberglass batting for 1°F Temp difference at insulation surface
That's how. Sometimes they need to design for a maximum allowed surface temperature when human contact is likely. For instance if you are on a ladder working next to a steam pipe, you don't want to suddenly jerk away from a hot surface!
Have Fun!
p.s. Actually the original image showed a K of 0.2. (K is thermal conductivity in metric units, and R is thermal resistance in English units.) Since there was no dimension given, that could be interpreted as the total conductivity of the insulation. If you use that interpretation, and the Rule of Thumb above, you have all the information needed to find the surface temperature. Or if this is a homework problem (likely), an analytical solution may be expected.
The only math is the temperature difference divided by R value per inch (182/4)? How is the 1 degree temp difference included in that?
Is the 1 BTU/Hr/Ft^2 the convection on the outside ?
I am ok in principle with most of the assumptions, but I'm sure you realize that an 8' diameter pipe that is almost entirely insulation is ridiculous. I too would have guessed that the surface temperature off by 1F was reasonable, but it turns out it isn't.
Well, that's a very very different requirement from being 1F off ambient. I think you'll find that it takes only a tiny amount of insulation - a fraction of an inch - to get hot steam piping down to a surface temperature you can touch. Generally, personnel protection is a secondary consideration; primarily the interest is minimizing heat loss (which wastes energy).
@anolan23, here is the piping insulation calculator I found:
https://checalc.com/calc/inshoriz.html
It doesn't go as cold as you are looking for, but if you use the same delta-Ts, you should get similar results. It also compares insulated pipe heat loss to bare pipe heat loss. I recently did a project where we specified 3" of insulation on 1" steam and condensate piping 350F and below. Using your delta-T (118F) for a 190F pipe gives a bare pipe loss of 243 BTU/h/ft and insulated pipe loss of 16 BTU/hr/ft. Surface temp 77F in a 72F room.
Likes Tom.G
You are right. That should have been 181/4 = 45.25" of insulation. Good catch anolan23!
Yes. With the assumption you want the outside surface temperature not more than 1°F different from ambient. If you can accept 10°F temperature difference you can reduce the insulation to around 4.3".
russ_watters said:
Using your delta-T (118F)...
The picture from th OP shows pipe temp. of minus 150.
anolan23 said:
Ambient is 32F
Likes anolan23
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 27 ·
