Why Do Tensile Cables Differ in Thickness?
  • Thread starter Thread starter jonnybmac
    Cables Tensile
Tensile cables differ in thickness compared to struts primarily due to their loading conditions. When cables are under tension, they experience axial loading, allowing them to utilize their strength effectively based on the force-to-cross-section area ratio. In contrast, compression members face buckling, which limits their maximum strength as described by Euler's column formula and the bending equation, both of which depend on the moment of inertia influenced by the member's shape. This fundamental difference in loading behavior explains why thinner wires are more efficient for tying purposes.
  • Understanding of axial loading and its effects on material strength
  • Familiarity with Euler's column formula and buckling concepts
  • Knowledge of bending equations and moment of inertia
  • Basic principles of tensile and compressive strength in materials
  • Research the mechanics of materials focusing on axial loading and buckling
  • Study Euler's column theory and its applications in structural engineering
  • Explore the relationship between moment of inertia and structural shape
  • Experiment with different materials under tension and compression to observe behavior
Structural engineers, materials scientists, and students studying mechanics of materials will benefit from this discussion, as it provides insights into the practical applications of tensile and compressive strength in design.
jonnybmac
Why are cables thin when used as ties? Why are they not equally as thick as say struts?
Is it because when in tension the tie cannot buckle? or because when in tension it cannot shear?
Steel has the same compressive strength as tensile, so why do they differ?
Many thanks for reading
I have tried looking on several forums on the internet as well as some educational sites and I oddly have no clue why thin wires are better at tying. The question is now stuck on my mind.
Is there anyone working in the practical field who can shed some information on this?
I think I have cracked it thank you.
When in tension it is only loaded axially so the strength is force the over cross-section area, but in compression you have buckling that stops the member reaching its maximum strength, and that if you look at the bending equation or Euler's column formula, they both rely on the moment of inertia which is affected by shape.
Thanks, I'll look into it.
You could look at the equations or you could play with some copper wire in your hands. See how it feels under tension and compression.
24K
11K
