Is Tensile Force the Same as Tension in Physics Calculations?
The discussion clarifies that tensile force and tension are effectively the same in the context of physics calculations. A specific example involves calculating the tensile force on a steel cable supporting a 420 kg iron girder, where the correct calculation is T = mg, resulting in a tensile force of 4,116 N (or 4.12 kN) when using g = 9.8 m/s². Misunderstandings arose from incorrect unit usage and mathematical operations, emphasizing the importance of clarity in equations and units in physics.
  • Understanding of Newton's Second Law (F = ma)
  • Basic knowledge of gravitational force (g = 9.8 m/s²)
  • Familiarity with units of measurement in physics (N, kg, m/s²)
  • Ability to perform basic algebraic calculations
  • Study the derivation and application of Newton's Second Law in various contexts.
  • Learn about the differences between tension, tensile force, and tensile stress.
  • Explore unit conversion techniques and the significance of dimensional analysis in physics.
  • Review algebraic principles relevant to physics calculations, focusing on exponents and unit manipulation.
This discussion is beneficial for physics students, educators, and anyone involved in engineering or construction who needs to understand the principles of tension and tensile forces in structural applications.
jbrandon
This question is confusing me, trying to find an equation for "tensile force" has left me confused since I've found no equation for it just for tension, tensile stress and tensile strain, just wanting to make sure I've not missed anything or done it incorrectly
1. Homework Statement
At a building site, an iron girder of mass 420 kg is suspended from a crane
by a steel cable. Assume that the cable has a circular cross-section of
diameter 25 mm.
Determine the tensile force in Newtons on the cable in kN to 2 decimal
places. (Take the acceleration due to gravity as 9.8 m s−2 and ignore the
mass of the cable).
i calculated it as tension assuming tensile force means tension[/B]
T = mg x ma
(420kg x 9.8ms2) x (420kg x 9.8ms2) = 8232 kg ms2
which i then converted to Newtons = 8232N (8.23Kn)
This is not correct. The tension in the cable is just equal to the weight of the girder.
what about the gravitational force ? also is tension the same as tensile force or are they 2 separate measurements ?
The gravitational force is the same thing as the weight.
Chet
Chet
so basically the tensile force is 420N or 0.42Kn, are tension and tensile force 2 different measurements or the same ?
T = mg x ma
It's not clear where you got this equation. BTW, it's meaningless.
(420 × 9.8) × (420 × 9.8) = (420 × 9.8)2 ≠ 8232
Also, what are the units here? Hint: they're not kg⋅ms2
Remember, g = 9.8 ms-2, which is not the same as 9.8 ms2. Things like - signs and × signs are important.
They are different terms for the same thing.
Chet
SteamKing said:
It's not clear where you got this equation. BTW, it's meaningless.(420 × 9.8) × (420 × 9.8) = (420 × 9.8)2 ≠ 8232
The formula I used was
T = mg + ma
T = tension, N, kg-m/s2
m = mass, kg
g = gravitational force, 9.8 m/s2
a = acceleration, m/s2
T = mg + ma
m = mass, kg
Using × in place of + suggests something else. × means multiplication. + means addition.
The formula T = mg + ma should be used only when there is some other acceleration a acting on m besides gravity g.
Sorry I didn't catch that I'd used x rather than +, I used + In my actual calculation.
So using 9.8ms-2 and not applying gravity as the acceleration would give me
(420kg x 9.8ms-2) + (420kg x 0) =
Or since there is no acceleration not include it at all like this?
(420kg x 9.8ms-2) + 420kg =
According to this calculation, you're saying that 420 kg × 0 = 420. Is that some kinda Common Core math?
Where did I say that? This is the new equation I've come up with following the advice from this thread
Compare you final two equations in post #10.
Chet
Chet
Those are 2 different equations, the first is where I've left acceleration in and the second is where I've removed it leaving only mass
In that case, the first equation is correct and the second equation is incorrect.
Yeah, but force = mass × acceleration
Setting acceleration to zero means the force = 0, by definition.
You can't be careless with equations, math, or units. These will cost you points on exams and assignments when studying physics if you don't make sure they're all correct.
This is why I'm here to gain a better understanding and learn
So the correct equation would be
(420kg x 9.8ms-2) + (420kg x 0) = 4.37kg m/s-2
I'm not sure how you can multiply 420 kg by 9.8 m/s2 and wind up with 4.37 kg-m/s2. That doesn't make sense arithmetically.
Also, kg m/s-2 is not the same as kg m/s2. Have you studied algebra yet? The laws of exponents?
I haven't studied any algebra yet this is the first month of my distance learning degree, I multiplied it by 9.8m/s-2 [/SUP ] to get that answer
Well, 420 x 9.8 ≠ 4.37
You should be able to estimate what the answer should be without a calculator.
The calculation I used wasw 420 x 9.8-2
So the correct way is the way you've presented to me?
You must learn to distinguish the units (ms-2) from the magnitudes (the numbers, like 9.8 or 420).
If you see 9.8 ms-2 written, that means 9.8 meters per second per second, not 9.8-2 meter seconds. If you're going to study physics, it is essential that you learn what units go with what physical quantities. For example, acceleration always has units of ##\frac{distance}{time^2}##, or distance⋅time-2 as it is sometimes written.
If you want to indicate that something happens to the magnitude of a given unit, then you must show that operation directly on the magnitude.
For example, the area of a square is the square of the length of the sides, or A = L2. If a certain square has a side which measures 4 meters, or L = 4 m, then you would show the calculation of the area of the square as
A = L2 = 42 m2 = 16 m2, or sometimes
A = (4 m)2 = 16 m2
This is why I had asked in a previous post if you had studied algebra or the laws of exponents. A lot of these misconceptions would have been prevented from forming in your mind by this additional study.
A = (4 m)2 = 16 m2
Thank you for the explanation, I have just got the mathematics for engineering book so I'll be studying that alongside my actual study to try and bring myself up to speed
  • · Replies 19 ·
  • · Replies 20 ·
