Tension and Torque homework challenge problem.
The discussion revolves around a physics homework problem involving a 4 kg mass and a 3 kg mass connected by a cord over a pulley with a moment of inertia of 0.5 kgm² and a radius of 0.3 m. The user calculated the acceleration and tensions T1 and T2, arriving at T1 = 26.76 N and T2 = 9.37 N. Feedback highlighted that the mass of the pulley was unnecessary for the calculations, and the formula for rotational inertia should be I = 1/2 mR² for a uniform disk. The user's final answers were confirmed as correct.
  • Understanding of Newton's second law of motion
  • Familiarity with torque and rotational dynamics
  • Knowledge of moment of inertia concepts
  • Ability to solve linear equations
  • Study the concept of moment of inertia for different shapes, specifically uniform disks
  • Learn about the relationship between linear acceleration and angular acceleration
  • Explore advanced problems involving pulleys and multiple masses
  • Review the principles of tension in connected systems
Students preparing for physics exams, particularly those focusing on mechanics, as well as educators looking for examples of tension and torque problems in introductory physics courses.
Tlocc
A 4KG mass is connected by a weightless cord to a 3 kg mass on a smooth surface. The pully rotates about a frictionless axle and has a moment of inertia of 0.5 kgm^2 and radius of 0.3m. Assuming that the cord does not slip on the pully, find a.) the acceleration of the two masses and b.) the tensions T1 and T2.
Click the image below to expand it to see what this looks like.
http://img98.imageshack.us/img98/1032/47770145rn2.th.png
T1=39.24-ma
T2=3a
Torque1=0.3T1
Torque2=0.3T2
I=mr^2
Torque=Parallel force x radius
Net Torque=Ialpha
I started by finding the mass(M) of the pully.
0.5=0.09M
M=5.56
I then used the net torque equation, substituting a/r for alpha.
nettorque=1.67a
I then summed my torques to this.
torque1-torque2=1.67a
0.3T1-0.3T2=1.67a
0.3(T1-T2)=1.67a
T1-T2=5.56a
Next I substituted my tensions in.
(39.24-4a)-3a=5.56a
39.24=12.56a
3.12a
I figured that now I could substitute the acceleration back in my original tension equations to find the tensions.
T2=3(3.12)
T2=9.37
T1=39.24-12.48
T1=26.76
There is no answer in the back of the book for this one, and I want somebody to check(rather than skim) my work and tell me if I have come to the right conclusion. If not, please tell me what I have done wrong. It's important that I can do this kind of equation for this week's test.
Looks good to me except for this first step:
0.5=0.09M
M=5.56
(1) You don't need the mass of the pulley, only the rotational inertia, which is given.
(2) Your equation for rotational inertia (I = mR^2) is incorrect; if you model the pulley as a uniform disk, I = 1/2mR^2.
Luckily, you made no further use of this calculation, so the rest of your work is fine.
Your answers are correct.
Thanks I'll found out later what the verdict is.
I was the only one in the class who got it right. Thanks for checking my work guys X)
