Tension in a Pendulum String - Oh my
The discussion focuses on calculating the tension in a pendulum string when a 0.030 kg mass is released from a 25° angle. The correct formula used is T = mg sin(65°), leading to a tension value of 0.27 N. The conversation clarifies that while centripetal force is zero at the extreme position, this does not imply that tension is zero. The net force in the radial direction must account for gravitational forces.
  • Understanding of basic physics concepts such as tension and centripetal force.
  • Knowledge of trigonometric functions, specifically sine, in relation to angles.
  • Familiarity with Newton's laws of motion.
  • Ability to perform calculations involving mass, gravity, and angles.
  • Study the derivation of tension in pendulum systems using different angles.
  • Learn about the effects of mass and length on pendulum dynamics.
  • Explore the relationship between centripetal force and tension in circular motion.
  • Investigate the role of gravitational force in pendulum motion at various angles.
Students studying physics, particularly those focusing on mechanics and pendulum motion, as well as educators looking for examples of tension calculations in pendulum systems.
Engineering101
So I have one attempt left and want to make sure my answer is correct, so double checking me would be super awesome!
You are given a pendulum composed of a 0.030 kg mass on the end of a 0.42 m long massless string. The pendulum is moved 25° from the vertical and released. Find the tension in the string when the mass is at the release point,
θ = 25°.
Tsin(65)-mg=0
Tsin(65)=mg
T=.32 N
This is one solution I came up with.
The other option I am unsure of is if the T force would be 0 because "there is no net force directed along the axis that is perpendicular to the motion. Since the motion of the object is momentarily paused, there is no need for a centripetal force." -http://www.physicsclassroom.com/class/waves/u10l0c.cfm
Thanks for the guidance.
The centripetal force is indeed zero in the extreme position. However this does not imply T=0.
The net force along the radial direction should be zero. And this net force includes gravity's contribution as well.
The first "option" is not good because the body's acceleration along the vertical direction is not zero.
Likes harmyder
So,
Fradial= -T + mgsin(65)
T=mgsin(65)
T=.27 N
θ = 25°.
"The centripetal force is indeed zero in the extreme position. However this does not imply T=0.
The net force along the radial direction should be zero. And this net force includes gravity's contribution as well."--nasu
So,
T=mgsin(65)
T=.27 N
θ = 25°.
So,
T=mgsin(65)
T=.27 N
It is correct.
ehild
  • · Replies 21 ·
