Tensor product basis in Cooperstein's Theorem 10.2
Math Amateur
MHB
I am reading Bruce N. Coopersteins book: Advanced Linear Algebra (Second Edition) ... ...
I am focused on Section 10.1 Introduction to Tensor Products ... ...
I need help with another aspect of the proof of Theorem 10.2 regarding the basis of a tensor product ... ...Theorem 10.2 reads as follows:
Screenshot of a textbook page showing Theorem 10.2 on tensor product bases and its proof, with the proof's steps about multilinear maps and the restriction to a basis written in plain text.
A diagram involving the mappings [itex]\iota[/itex] and [itex]\gamma'[/itex] is as follows:
Handwritten diagram for Theorem 10.2: X = V1 x V2 x ... x Vm and X' = B1 x B2 x ... x Bm; two nested circles X and Z with inner regions X' and Z', maps i: X to Z and gamma': X to Z', points x in X\X' and z in Z\Z'.
My questions are as follows:Question 1
How do we know that there exists a multilinear map [itex]\gamma' \ : \ X \longrightarrow Z'[/itex] ?
Question 2What happens (what are the 'mechanics') under the mapping [itex]\gamma'[/itex] ... ... to the elements in X\X' ( that is [itex]X - X'[/itex])? How can we be sure that these elements end up in [itex]Z'[/itex] and not in Z\Z'? (see Figure 1 above)
Hope someone can help ...
Peter
  • Text of Theorem 10.2 and its proof from a linear algebra textbook, covering a basis for the tensor product of vector spaces V1 through Vm built from basis tensors, with the proof using a multilinear map and an isomorphism.
  • Handwritten diagram for Theorem 10.2: X = V1 x V2 x ... x Vm and X' = B1 x B2 x ... x Bm; two nested circles for X and Z, with inner subsets X' and Z', maps i: X to Z and gamma': X to Z', and points x in X\X' and z in Z\Z'.
Re question 1:
Let ##V^\dagger\equiv V_1\times,...,\times V_m## and let's use angle brackets [itex]\langle...\rangle[/itex] to enclose components of Cartesian product spaces. Let the components of [itex]\mathscr{B}_j[/itex] be [itex]v_{j1},...,v_{jn_j}[/itex] where [itex]n_j[/itex] is the dim of [itex]V_j[/itex].
You haven't said what [itex]Z[/itex] is but let's assume it's the infinite-dimensional vector space over field [itex]F[/itex] with base set
$$\mathscr{B}^Z\equiv \{\langle u_1,...,u_m\rangle\ |\ \forall k:\ u_k\in V_k\}$$
More formally, [itex]Z[/itex] is the set of all functions from [itex]\mathscr{B}^Z[/itex] to [itex]F[/itex] for which each such function has finite support (ie is nonzero on only finitely many input values).
[itex]Z'[/itex] is the subset of [itex]Z[/itex] containing only functions whose support lies in [itex]X'[/itex], and it is easily shown to be a subspace.
Define the map [itex]\xi:X'\to Z'[/itex] that maps each Cartesian product of basis vectors [itex]\langle v_{1i_1},...,v_{mi_m}\rangle[/itex] to the function that returns zero for every input except [itex]\langle v_{1i_1},...,v_{mi_m}\rangle[/itex], for which it returns [itex]1_F[/itex]. Note that the image of [itex]\xi[/itex] is a basis for [itex]Z'[/itex].
Then a map [itex]\gamma':V^\dagger\to Z'[/itex] is multilinear, and agrees with [itex]\xi[/itex] on [itex]X'[/itex], if and only if it satisfies:
\begin{align*}
\gamma'\left(\left\langle \sum_{i_1}a_{1i_1}v_{1i_1},\, ...\, ,\sum_{i_m}a_{mi_m}v_{mi_m}\right\rangle\right)
&=\sum_{i_1}\sum_{i_2}\ ...\ \sum_{i_m} \prod_{k=1}^m a_{ki_k}\gamma'\left(\left\langle
v_{1i_1},\, ...\, ,v_{mi_m}\right\rangle\right)
\xi\left(\langle v_{1i_1},...,v_{mi_m}\rangle\right)
\end{align*}
where the first equality implements multilinearity and the second implements the requirement to agree with [itex]\xi[/itex].
Since [itex]X'[/itex] is a basis for [itex]V^\dagger[/itex], it follows that such a map [itex]\gamma'[/itex] exists. It is unique because the representation [itex]\sum_{i_k}a_{ki_k}v_{ki_k}[/itex] of the [itex]k[/itex]th coordinate of the input to [itex]\gamma'[/itex] is unique.
Andrew,
Going through your post carefully shortly ...
Cooperstein provides a definition of Z in the introduction to Section 10.1 including in the proof of Theorem 10.1 ...
Relevant text from Cooperstein is as follows:
Printed textbook page, Section 10.1 Introduction to Tensor Products, with Definition 10.1 of a vector space based on a set X and Figure 10.1, a commutative triangle diagram with maps i from X to V, j from X to W, and T from V to W.
Commutative diagram with nodes X, V and W: an arrow i from X to V, an arrow T from V to W, and an arrow j from X to W. Below it is the printed solution text for Figure 10.2 on vector space spaces of functions over X.
Scanned textbook page of linear algebra text: Definition 10.2 of a tensor product of vector spaces, Remark 10.1, Notation, Lemma 10.1 with parts i and ii, and the start of its proof.
Printed textbook page with the proof of Theorem 10.1 on the tensor product of vector spaces, defining the space X = V1 x ... x Vm and the quotient space V = Z/U with the map gamma.
Hope that helps ...
Peter
  • Textbook page titled 10.1 Introduction to Tensor Products, with Definition 10.1 of a universal mapping problem and Figure 10.1 showing a commutative diagram: map i from X to V, map j from X to W, and linear map T from V to W with j = T o i.
  • Commutative diagram of linear maps: a map i from set X to vector space V, a map j from X to vector space W, and a map T from V to W, labeled as a textbook figure titled Figure 10.2, Solution: Vector space based on the set X.
  • Scanned page of a linear algebra textbook showing a multilinear map definition, a tensor product definition (Definition 10.2), Remark 10.1, notation for composition, and Lemma 10.1 with its proof.
  • Printed page of a textbook proof of Theorem 10.1 on the tensor product of vector spaces, covering the construction of the quotient space V = Z/U with the map gamma from V1 x ... x Vm to V.
