Terminal velocity and drag force in one dimention
In one-dimensional motion, a particle's velocity approaches terminal velocity regardless of the forces acting on it. The equation mv' + bv = F(t) indicates that as time tends to infinity, the velocity converges to F(c)/m, where c is a constant. A mathematical theorem suggests that if certain conditions are met, the integral of the product of continuous functions can yield a constant value. The discussion also highlights the importance of correctly determining the limits in the theorem. Overall, the analysis supports the idea that terminal velocity is reached under the specified conditions.
Lucien1011
In one dimensional cases, will the velocity of a particle tend to the terminal velocity unregardless of any combinations of forces?
I try to investigate this equation: mv'+bv=F(t)
Using the mathematics theorem at the botton, I found that v --> F(c)/m as t tends to infinity. (where c is some constant)
[Thm: if w(x) and u(x) are continuous functions and u(x)>=0, then for a<=x<=b, then {w(x)u(x)}:b,a=w(c)*{u(x)}:b,a for some c lies between a and b]
the notation {f(x)}:b,a represents the definite integral from a to b with repect to x. Sorry for the unusual notation, as I don't know how to type the integral.
Sorry for the poor presentation too. I intended to write the result on a piece of paper and scan it into the computer but my scanner is out of order now.
Looks fine to me if the theorem is correct. How are you going to determine the value of c?
Oh yeah. I neglect that the upper and lower limit in the thm should be constants.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
