The acceleration of a particle on a horizontal xy plane
The acceleration of a particle on a horizontal xy plane is defined by the equation a = 3ti + 4tj, where 'a' is in meters per second-squared and 't' is in seconds. To determine the position vector at t = 4.00 s, one must integrate the acceleration to find the velocity and then integrate the velocity to find the position. The initial conditions provided are r = (20.0m)i + (40.0m)j and v = (5.00m/s)i + (2.00m/s)j. The integration process yields the equations dx = 1.5t^2 + vcos(0)t + 20 and dy = 2t^2 + vsin(0)t + 40, allowing for the calculation of the angle between the direction of travel and the positive x-axis using the dot product.
  • Understanding of vector calculus
  • Familiarity with integration techniques
  • Knowledge of initial conditions in physics problems
  • Proficiency in using dot products for angle calculations
  • Learn how to integrate vector functions in physics
  • Study the application of initial conditions in motion equations
  • Explore the use of dot products to find angles between vectors
  • Investigate the relationship between acceleration, velocity, and position in kinematics
Students and professionals in physics, particularly those focusing on mechanics and kinematics, as well as educators teaching these concepts in a classroom setting.
kara
The acceleration of a particle on a horizontal xy plane is given by a=3ti + 4tj, where a is in meters per second-squared and t is in sec. At t=0, the particle has the position vector r=(20.0m)i + (40.0m)j and the velocity vector
v=(5.00m/s)i +(2.00m/s)j. At t=4.00 s, what are its position vector in unit-vector notation and the angle between its direction of travel and the positive direction of the x axis?
I have no idea what to do at all https://www.physicsforums.com/images/smilies/surprised.gif
Find the general equations for position and velocity by integration and use the initial conditions.
"the angle between its direction of travel and the positive direction of the x axis"
For that you can apply the dot product.
so would i integrate a to find position and then velocity?
You integrate acceleration to find velovity, and then integrate velocity (after plugging in the initial condition) to find position.
alright so i got:
dx = 1.5t^2 + vcos0t + 20
dy = 2t^2 + vsin0t + 40
where the 0 is theta
kara said:
alright so i got:
Bringing in new variables (such as theta) without any need will just make the answer more complicated.
Here's an example on how to go about the problem:
\frac{dv_x}{dt} = 3t
v_x = \frac{3}{2}t^2 + C (C is the constant of integration)
Now put in the initial condition, the value for v_x when t = 0 and find the value for C. Similaraly find v_y. The process is the same for finding position.
You can be a bit more formal and use \vec{v}(t) = \int \vec{a}(t)dt + \vec{v}_{0}, i.e. \vec{r}(t) = \int \vec{v}(t)dt + \vec{r}_{0}, but basically that's the same thing Neutrino wrote.
