The C is the speed of photon ( light ) ?
  • Context: High School
  • Thread starter Thread starter dailydc
    Light Photon Speed
The discussion revolves around the interpretation of the symbol "c" in Einstein's equation E=mc², specifically whether it represents the speed of photons in a vacuum or if it has broader implications as a fundamental constant of the universe. Participants explore the nuances of light's speed in different contexts, including gravitational effects and local versus non-local measurements.
  • Some participants assert that "c" is the speed of photons in a vacuum, while others suggest it is a fundamental constant not limited to photons.
  • One participant mentions that "c" could be attributed to the speed of gravity and other forms of energy in a vacuum.
  • Another participant introduces the idea that light's speed can appear slower than "c" when measured through a gravity well, depending on the observer's position.
  • Concerns are raised about defining the velocity of a photon in a global context, with some arguing that spacetime curvature complicates this definition.
  • There are references to Einstein's General Relativity and how it relates to the perceived speed of light in gravitational fields.
  • One participant provides links to external sources discussing the variability of light's speed in different gravitational contexts.
  • Another participant notes that while local measurements yield "c," non-local measurements can suggest variations in light's speed due to gravitational influences.
Participants express differing views on whether "c" is strictly the speed of photons or a broader constant. There is no consensus on the implications of gravitational effects on the speed of light, with multiple competing interpretations presented.
Some statements rely on specific interpretations of gravitational effects and local versus non-local measurements, which may not be universally accepted. The discussion includes references to external sources that may not be verified within the thread.
  • #31
rede96 said:
Sorry if this is a bit off-topic but I would be interested to know if length contraction had been tested in the way you describe above? (Or just info on anyway it had been tested please.) Thanks.
No, it has not.
Because we cannot get any macro body to accelerate to a luminal enough velocity, there has been no direct measurement of length contraction to date. We accelerate subatomic particles in the supercolliders, however being so tiny, there's no hope there. However, we have verified these relativitic effects by experiment just to name a few ... relativistic mass increase, time dilation, frame dragging, moving clocks tick slower, higher clocks tick slower, cosmological redshift, etc. Since all relativistic effects arise in unison with relative motion, it's rather unfathomable to imagine a body would not length contract when moving relatively ... all the relativistic effects are differing aspects of a single underlying mechanism.
GrayGhost
  • #32
harrylin said:
Even in classical mechanics you can Galileo boost to the rest frame of a moving object and thus transform away its speed. Do you think that this makes the concept "speed" useless, so that mechanics is useful without it? :-p
But that is again coordinate speed. You can do the same thing in relativity. What is meaningful however, with regards to the object's 4 - velocity, is [itex]U^{\alpha }U_{\alpha }[/itex] because it will not change when you define new coordinate functions and apply transformation laws to all respective quantities.
  • #33
DaveC426913 said:
A photon does move at c in a vacuum, yes. But c is a fundamental constant of the universe; it is not specific to the speed of photons.
Hello everyone again
I research hard but answer is no !
So what's your idea ?See my explanation and Argument
Refer to the link
https://secure.wikimedia.org/wikipedia/en/wiki/Speed_of_light
And this explanation
The speed of light (meaning speed of light in vacuum), usually denoted by c, is a physical constant important in many areas of physics. Its value is 299,792,458 metres per second
focus on vacuum
Means that vacuum is perfect vacuum
But we know that there are no perfect vacuum because free-space have minimum of energy
Refer to the link
http://en.wikipedia.org/wiki/Vacuum_energy
So we have real vacuum or partial vacuum and we can not find any perfect vacuum
Code:
Physicists often discuss ideal test results that would occur in a perfect vacuum, which they simply call "vacuum" or "free space", and use the term partial vacuum to refer to real vacuum.
Conclusion :if photons travel or move at a perfect vacuum there are does move at C
But there are no perfect vacuum at all and photons move at partial vacuum so they lose a little of their speed .
So
photons does not move at "c" in our universe even if they are in free-space .
Hope undesrtand
  • #34
Actually photons always travel at c (whether they are in a vacuum or not) even though light, in an imperfect vacuum, may travel slightly slower than c.
When a photon hits an atom, it may be absorbed by the atom, then, after a short delay, another photon is emitted. Delays like this mean that the average speed of light can be less than c even though each individual photon travels at exactly c.
The above explanation is over-simplified. For a more accurate explanation see the FAQ https://www.physicsforums.com/showthread.php?t=511177
  • #35
I research hard but answer is no ! So what's your idea ?
So photons does not move at "c" in our universe even if they are in free-space . Hope undesrtand
Put like that, photons are never in perfectly free space. But I think that in high vacuum light (incl.photons) propagates at 299,792,458 m/s. That's perfect enough for me. :smile:
  • #36
bcrowell said:
[..] coordinate velocities[..] do not correspond in any way to observations. [..].
WannabeNewton said:
But that is again coordinate speed. You can do the same thing in relativity. [..]
Exactly, and coordinate speed - which is what is actually measured - is just as useful there. Again: do you really think that coordinate speed in mechanics is useless, so that rocket science and GPS are useless too?! :wink:
  • #37
No, coordinate speed is never measured. It can't be measured, because it has a different value if you describe the problem in different coordinates. For example, the redshift of a photon from a distant galaxy is what is measured. The coordinate velocity of the distant galaxy is not measured; it isn't even defined unless I first choose coordinates.
The distinction in Newtonian mechanics is unimportant, since Newtonian mechanics has an unambiguously defined way of talking about the velocity of object A relative to distant object B. GR doesn't.
I don't claim that coordinate-dependent quantities are completely useless. They are often useful, and I said so in #29, where I made the analogy with the phase of an electron's wavefunction, which is useful but not measurable. GPS uses coordinates called earth-centered inertial (ECI). They are useful. It's necessary for GPS to choose some coordinates. However, the choice is arbitrary, and therefore the coordinates don't correspond to measurable quantities.
  • #38
As a general rule, in curved spacetime coordinate values are not directly measured; you usually need to apply some conversion factor, except at those events where the components of the metric are equal to those of the Minkowski metric. That's what the metric is for, to convert coordinate values into "physically meaningful" quantities such as proper time and proper length.
I don't think anyone has claimed that coordinate speed is useless; the expressions used were "not physically meaningful" and "of no physical interest". My previous paragraph supports those views.
The only speed you can measure directly is between two particles whose worldlines intersect at a common event. When particles are separated you run into the old "parallel transport" problem and you have to agree on an artificial (i.e. coordinate-dependent) convention on how to parallel-transport one vector to the other. Having such a convention can be extremely useful but nevertheless the resulting coordinate velocity isn't "physically meaningful".
  • #39
Not to beat a dead horse, but here's another point to help try to explain what DrGreg and I have been saying in the last couple of posts. Let's take a specific galaxy, UDFy-38135539, which is one of the most distant ever observed. You can find information about it by googling. Its redshift is 8.55. What is its coordinate speed relative to us? The answer is that its coordinate speed can be anything I like. I can choose coordinates in which a galaxy moving with the Hubble flow has all its coordinates constant except for t; in such coordinates, both UDFy-38135539 and our own galaxy have coordinate speeds that are nearly zero. I can choose other coordinates such that our own coordinate speed is still zero, but UDFy-38135539's is some fraction of c. I can also make it equal to c, or greater than c.
  • #40
Thank you for good replying .
Can i really trust to the Article of Sir ZapperZ ?
As a science it has to be invoked ?
It was a good information for me .
  • #41
That one was written before I was here, but anyway our current process for posting a FAQ entry is that it goes through a process of review by the mentors, and it doesn't get posted unless it reflects their consensus. Of course, the best thing is to be able to evaluate for yourself whether you trust a particular argument, rather than trying to figure out whether the source is authoritative.
  • #42
dailydc said:
So the feature of space causes Photons can not easily move at "c" in vacuum and decrease their speed . is that true ?
In some sense this is true. For example, the paper first describing http://en.wikipedia.org/wiki/Shapiro_delay" says "Because, according to the general theory, the speed of a light wave depends on the strength of the gravitational potential along its path, these time delays should thereby be increased ..."
However, the "speed of light over a large distance" and a "gravitational potential" are not always meaningful concepts, and are a somewhat looser way of speaking.
Instead, the more general idea is that the *local* speed of light is always the same. That idea completely determines the paths of light rays in curved spacetime. An equivalent way of stating this is "light rays follow null geodesics".
  • #43
A precision here, as "local" can stand for different things: with "the local speed of light is always the same" you surely mean, not the local speed of light along its path as determined with a single reference standard for length and time (Shapiro, GPS, etc), but the local speed of light as measured with multiple *local reference systems* along its trajectory.
Harald
  • #44
DrGreg said:
[..] The only speed you can measure directly is between two particles whose worldlines intersect at a common event. [..]
bcrowell said:
No, coordinate speed is never measured. It can't be measured, because it has a different value if you describe the problem in different coordinates. For example, the redshift of a photon from a distant galaxy is what is measured. The coordinate velocity of the distant galaxy is not measured; it isn't even defined unless I first choose coordinates.[...]
As this is rather off-topic, here's my last comment. Measuring is based on a chosen measurement system with measurement standards to which one relates. Again: GPS definitely uses coordinate speed; and I guess that most people would agree that what GPS does, is "measuring". :-p
I don't claim that coordinate-dependent quantities are completely useless. [..]
Good that that misunderstanding has been settled. :smile:Harald
  • #45
Hello again
Everyone can explain why speed of photon decrease in a gravitational field or Bose–Einstein condensate ?
We Know bosons aren't atom
  • #46
dailydc said:
Hello again
"A Bose–Einstein condensate (BEC) is a state of matter of a dilute gas"
- http://en.wikipedia.org/wiki/Bose–Einstein_condensate
Harald
  • #47
Harald
Yes , You're right .
I must see english wikipedia
Since english is not my first or seconds language , i always see our wikipedia language
And in that page was no reference to this case . sorry
But
Can you explain why speed of photon decrease in a gravitational field ?
  • #48
It doesn't decrease in any inertial frame, but with tidal gravity present there are no global inertial frames.
  • #49
But
Wikipedia isn't very reliable but usually it's a good place to start. :smile:
About the "why" we can only form hypotheses, and different people tend to give different answers to "why" questions - but see my post #11.
In other words, the speed of light (as well as many other things) is determined by the local state of the space through which it propagates. Thus Einstein came to admit: "the fact that "empty space" in its physical relation is neither homogeneous nor isotropic, [...] has, I think, finally disposed of the view that space is physically empty."
- http://en.wikisource.org/wiki/Ether_and_the_Theory_of_Relativity
  • #50
So what's shapiro effect ?
  • #51
I think you mean, how is it consistent with my comment. The Shapiro effect does not occur in an inertial frame, it only occurs where there is tidal gravity and therefore no global inertial frames.
If you really just want to know what it is: http://tinyurl.com/3t5y4gj
  • #52
I answered your question already (before you asked it) in my post #11 :wink:
  • #53
From the FAQ: Do Photons Move Slower in a Solid Medium?
So the lattice does not absorb this photon and it is re-emitted but with a very slight delay. This, naively, is the origin of the apparent slowdown of the light speed in the material. The emitted photon may encounter other lattice ions as it makes its way through the material and this accumulate the delay.
I am confused about this statement from the FAQ mentioned earlier, first it says "the lattice does not absorb this photon" then is says "and it is re-emitted". How can it NOT be absorbed and still be emitted?
Bob
  • #54
Given that if you perform a local experiment the speed of light is always "c" , regardless of gravity, whether you're deep in a gravity well or far outside it, what do people mean when they say "the speed of light varies"?
What they mean is that in some particular coordinate system, the rate of change of the position coordinate with respect to the time coordinate isn't always the same.
This really has more to do with the behavior of coordinates than any property of light itself.
It's a bit like saying that naval vessels "move faster" when they are near the north pole, because the rate of change of the lattitude with respect to time is greater.
  • #55
Don't you mean longitude?
  • #56
Yes - good catch...
  • #57
What they mean is that in some particular kind of coordinate system, the rate of change of the position coordinate with respect to the time coordinate isn't always the same.
For one, I don't mean that when I say that. :wink:
Instead, I mean that for *any* "universal" coordinate system (that uses single, non-local standards for length and time) the speed of light isn't *everywhere* the same. Only for a particular coordinate system that is kept very small, or one that has "elastic units", the speed of light is "always c".
It's a bit like saying that naval vessels "move faster" when they are near the north pole, because the rate of change of the [longitude] with respect to time is greater.
The Earth is a physical object to which those coordinates relate. Thus, do you mean that:
1. there is a physical equivalent to the Earth, but which we cannot see?
or
2. that it's an artifact of using a certain kind of coordinate system?
- if 1.; what is it?
- if 2.; then Einstein's light bending calculation was based on a mere artifact. Then how do you explain the bending of light?
Harald
  • #58
You seem to keep confusing coordinate systems and what is physically happening. Yes [itex]\frac{\mathrm{d} \phi }{\mathrm{d} y}[/itex] for a photon uses a specific coordinate system but it can be done in any arbitrary coordinate system and so the coordinate value is ambiguous even though physically light does bend. People use the coordinate system that is the easiest to work with and that allows one to define classical parameters. You could use a convoluted coordinate system for the schwarzschild metric that results in some crazy value for [itex]\frac{\mathrm{d} \phi }{\mathrm{d} y}[/itex] for the photon but it is easier to make sense of certain parameters when the coordinate system itself is logical, like the impact parameter for the photon which is [itex]b = L/E[/itex] which would be easily definable in the usual coordinate system for the schwarzschild metric but not so in some other coordinate system. But the physical action of light bending is still happening, we just use a certain system to quantify it. Also, for an arbitrary manifold it is not always possible to construct an atlas with a single, universal coordinate chart. In general, a maximal atlas on a manifold will contain multiple smoothly sewn coordinate charts.
  • #59
WannabeNewton said:
[..] But the physical action of light bending is still happening, we just use a certain system to quantify it. [..]
Perhaps you did not see my post #57? Thus my same question no.2 for you: If you think that Einstein's calculation is based on an artifact from choosing a certain coordinate system which gives a misleading result, then there should be no speed gradient and therefore there can be no light bending based on the wave model of light that he used for GRT. Thus how do you explain the effect? Clearly you do not deny that it occurs. :smile:
  • · Replies 120 ·
10K
  • · Replies 19 ·
  • · Replies 93 ·
  • · Replies 16 ·
  • · Replies 34 ·
