The conditions and assumptions for the Antoine equation?
The Antoine equation, represented as lnPsat=A-B/(T+C), is derived from the Clausius-Clapeyron equation, which describes the relationship between vapor pressure and temperature. The key assumptions for the validity of the Antoine equation include neglecting the specific volume of the saturated liquid compared to that of the saturated vapor, leading to ΔV being approximated as the specific volume of the saturated vapor. Additionally, the equation assumes a specific functional relationship between temperature T and the heat of vaporization ΔH. Understanding these conditions is crucial for accurate application of the Antoine equation in thermodynamic calculations.
  • Understanding of the Clausius-Clapeyron equation
  • Familiarity with the Antoine equation and its parameters (A, B, C)
  • Knowledge of vapor-liquid equilibrium concepts
  • Basic calculus for differentiation and integration
  • Study the derivation of the Clausius-Clapeyron equation in detail
  • Learn about the empirical nature of the Antoine equation and its applications
  • Explore the relationship between heat of vaporization ΔH and temperature T
  • Investigate other equations of state for vapor-liquid equilibrium
Chemical engineers, thermodynamicists, and students studying physical chemistry who need to understand vapor pressure calculations and the application of the Antoine equation in various thermodynamic scenarios.
Ortanul
Derive the basic relationship that the Antoine equation represents. Most importantly, explain the underlying condition when the Antoine equation applies and the underlying assumptions for the Antoine equation to be valid.
Clausius-Clapeyron Equation: dPsat/dT=ΔH/TΔV
Antoine Equation: lnPsat=A-B/(T+C)
Assume ΔV=Vgas-Vliq≈Vgas
From the Clausius-Clapeyron Equation, dPsat/dT=ΔH/(T*nRT/P)=ΔH/R * P/T2
Rearrange: dPsat/P=ΔH/R * dT/T2
Perform the integration, lnPsat=A-ΔH/RT=A-B/T, A, B are the constant
I think this should be the basic relationship of the Antoine Equation, even though C is not involved in the equation, as Antoine Equation is an empirical relationship.
However, I don't know what kind of conditions and assumptions I should make before using the Antoine Equation, and they are not explicitly stated in my textbook. Should I consider ΔV=Vgas-Vliq≈Vgas as one of the assumptions?
Any help will be appreciated!
I doubt it is valid to replace ΔV with V, as you have. That may explain the non-appearance of C.
You need to work backwards. Start with the Antoine equation, and take the derivative with respect to T. Then compare you result with what you get from the Clausius-Clapeyron equation. Then you will see how ΔH is related to the constants in the Antoine equation.
A key approximation in the derivation of the Clausius-Clapeyron equation is to neglect the specific volume of the saturated liquid in comparison to the specific volume of the saturated vapor. So ΔV is taken as the specific volume of the saturated vapor V.
I'll try to derive the equation again later. Thank you for your help!
Apart from that, if Antoine Equation can be fully derived from Clausius-Clapeyron Equation, I wonder why it is a empirical equation as stated on my book. Besides, could you please tell me if there is any other necessary assumption for the Antoine Equation itself apart from the negligible volume of liquid?
The Antoine equation assumes a particular functional form for the effect of temperature T on the heat of vaporization ΔH. You can see what that functional form is by taking the derivative of lnPsat with respect to T, and then setting that equal to the derivative of lnPsat with respect to T from the Clausius-Clapeyron equation. This will give you the functional form they assume for ΔH vs T in the Antoine equation.
Chet
