The Dirac equation in Weyl representation
7 replies · 4K views · last reply
Milsomonk
Compute the antiparticle spinor solutions of the free Dirac equation whilst working in the Weyl representation.
Dirac equation
$$(\gamma^\mu P_\mu +m)v_{(p)}=0$$
Dirac matrices in the Weyl representation
\gamma^\mu=
\begin{bmatrix}
0 & \sigma^i \\
-\sigma^i & 0
\end{bmatrix}, \
\gamma^0=
\begin{bmatrix}
0 & I \\
-I & 0
\end{bmatrix}
I have worked through the algebra numerous times but I can't seem to get the correct energy momentum relation out, my workings are attached, apologies I'm not too strong with Latex yet. Any ideas on where I may be going wrong would be greatly appreciated :)
Handwritten working on squared paper deriving the antiparticle spinor from the Dirac equation with Weyl-representation gamma matrices, ending in an energy-momentum relation line.
  • Handwritten working on squared paper deriving the antiparticle spinor from the Dirac equation with Weyl-representation gamma matrices, ending in an energy-momentum relation line.
Milsomonk said:
\gamma^\mu=
\begin{bmatrix}
0 & \sigma^i \\
-\sigma^i & 0
\end{bmatrix}, \
\gamma^0=
\begin{bmatrix}
0 & I \\
-I & 0
\end{bmatrix}
Are you sure you have the correct form for ##\gamma^0## in the Weyl representation?
Also, you haven't specified the sign convention that you are using for the Minkowski metric: (1, -1, -1, -1) or (-1, 1, 1, 1). The choice will determine which components of a 4-vector change sign when raising or lowering an index.
Ah somehow I managed to shove a minus sign in the gamma zero matrix that shouldn't be there. Also, sorry, I'm using mostly minus :). I have tried again with the correct matrices but I'm having a similar issue...
Handwritten derivation on grid paper of the Dirac equation in Weyl representation, showing gamma matrices as 2x2 block matrices, then block-matrix equations reduced to mη + (E + m - σ·p)χ = 0 and related steps.
  • Handwritten derivation on grid paper of the Dirac equation in Weyl representation, showing gamma matrices as 2x2 block matrices, then block-matrix equations reduced to mη + (E + m - σ·p)χ = 0 and related steps.
How did you get E+m in the locations indicated below?
Handwritten derivation of the Dirac equation in Weyl representation: gamma matrices in block form, then lines (gamma^mu p_mu + m) psi = 0 and a 4-component spinor equation, with orange circles marking terms.
Another thing to consider. For most people, the vector ##\vec p## would denote the 3-vector with contravariant components ##(p^1, p^2, p^3)##. So, for example, ##\gamma^1 p_1 = \gamma^1 (-p^1) = -\gamma^1 p^1##.
  • Handwritten derivation of the Dirac equation in Weyl representation: gamma matrices in block form, then lines (gamma^mu p_mu + m) psi = 0 and a 4-component spinor equation, with orange circles marking terms.
Hi,
Its just the mass term from the Dirac equation which I have to add to each matrix element, unless I've done something daft. Ah so my momentum terms should have an overall change of sign?
Milsomonk said:
Hi,
You don't want to add m to all the matrix elements. You should think of m in the Dirac equation as multiplied by the unit matrix.
Yes.
Thanks very much for your help :) Looks like I have the correct solution now.
