The Effect of Conductors on Electric Field Lines
The discussion revolves around the behavior of electric field lines in relation to conductors, particularly focusing on the effects of external charges and the conditions within cavities of conductive materials. Participants explore theoretical implications, the application of Gauss's law, and the behavior of charge carriers in electrostatic equilibrium.
  • Some participants assert that the electric field due to an external point charge cannot penetrate the conductor, leading to zero electric field within the conductor and its cavity.
  • Others question the claim that the electric field in the cavity is zero, suggesting that it only applies to points inside the conductor itself.
  • One participant references Gauss's theorem to explain the redistribution of charge carriers on the conductor's surface, which is said to ensure the electric field lines are perpendicular to the surface.
  • Another participant emphasizes that if there were an electric field within the conductor, it would cause charge carriers to move, contradicting the conditions of electrostatic equilibrium.
  • Participants express confusion about the mechanisms preventing external electric field lines from entering the cavity, seeking clarification on this point.
  • There is a discussion about the implications of the equations governing electrostatics, including the conditions for electric fields being zero within conductors and cavities.
Participants do not reach a consensus on the behavior of electric fields in cavities of conductors, with multiple competing views and ongoing questions about the underlying principles.
Limitations include assumptions about the uniformity of charge distribution and the specific conditions under which the electric field is considered to be zero. The discussion also reflects varying interpretations of Gauss's law and its implications for electric fields in conductors.
This discussion may be of interest to students and professionals in physics, particularly those studying electrostatics, conductive materials, and the behavior of electric fields in various contexts.
navneet9431
What is true is that the field due to the point charge outside of the conductor will not be able to penetrate the shell i.e. there will be no field due to the external point charge anywhere within the conductor nor in the cavity: the field will be **killed off*& by the charges on the outer surface of the conductor. Similarly, the field due to the point charge in the cavity will also vanish for all points exterior to the cavity because it will be **killed off** by the charges on the inner surface of the conductor.
Reference https://www.physicsforums.com/threads/electric-field-charge-inside-a-metallic-shell.692512/
Can you please explain this phenomenon of killing of electric field lines more clearly?
I will be thankful for help!
What would happen with the charge carriers if there would be an ##\vec E## field left over in the conductor ?
This is not correct -- only true for points inside the conductor!
Suppose,we have a solid spherical conductor with a cavity in it and a charge +q placed outside the sphere.Then how is the electric field inside the cavity zero?Can you please explain this?
Are you aware of the Gauss theorem ?
The charge carriers in the conductor will redistribute on the outside of the conductor in such a way that the ##\vec E\;## field lines are all perpendicular to the outer surface.
In the conductor itself there is no ##\vec E\;## field and on the inner surface the mirror charge is evenly distributed (can you see why ?) so there is no field inside the cavity.
Ok thanks!
I can see things getting clear..
But,what actually prevents the electric field lines generated by external charge *to penetrate and get inside* the cavity throght the material of the conductor and make the electric field inside the cavity non-zero?
this is my main doubt.
If an isolated conductor without cavities is charged, its excess charge will distribute itself on its surface in order to guarantee that the electric field is zero on its interior.
If instead the conductor had an interior cavity, the charges would again distribute themselves on the outer surface in order to eliminate the electric field on the inside material of the conductor. (Free electrons cannot move in equilibrium.) Why is the electric field within the cavity zero as well?
Or in other words,
Electrostatics with conductors is governed by the equations (in SI units)
$$\vec{\nabla} \times \vec{E}=0, \quad \vec{\nabla} \cdot \vec{E}=\frac{1}{\epsilon_0} \rho.$$
Within the conductors you must have ##\vec{E}=0##, because otherwise there were a current according to Ohm's Law, but electrostatics is defined such that there are no currents.
The first equation tells you that there is a potential
$$\vec{E}=-\vec{\nabla} \Phi.$$
At the boundaries of the conductors the tangential components of the electric field must be continuous and thus vanish, while the normal components jump by the amount ##\sigma/\epsilon_0##, where ##\sigma## is the surface-charge density on the surfaces. This implies that the surfaces of conductors are necessarily equipotential surfaces.
If there are no charges inside your cavities, there you have ##\Delta \Phi=0##, and the surfaces of the cavities are equipotential surfaces. Thus ##\Phi=\text{const}## is a solution inside the cavities, and since the Poisson and Laplace equations have unique solutions under the circumstances here, it's the only solution, but this implies that ##\vec{E}=-\vec{\nabla} \Phi=0## inside the cavities.
The mobility of the charge carriers ! (makes sense, since that is the distinguishing difference between a conductor and an insulator :smile:)
Can you agree there are no ##\vec E\,## field lines inside the conducting material ? If there were, charge carriers would move, right ?
