The expectation value of superimposed probability functions
11 replies · 2K views · last reply
redtree
I apologize for the simplicity of the question (NOT homework). This is a statistical question (not necessarily a quantum mechanical one).
If I have an initial probability function with an associated expected value and then a second probability function is superimposed on the initial probability function, how do I find resulting expectation value? Do I simply average the two expectation values (how do I weight?)? Would I use the convolution of the two probability functions to calculate the combined probability density function and then use that to calculate the resulting expected value? Or something else?
What exactly do you mean by "superimposed"?
Added? Average them, with the weight coming from the total integral of the functions.
Convoluted? Add the expectation values.
This is what I mean, though I am not sure if it is correct:
Given, where ##\vec{X}## and ##\vec{Y}## are independent variables:
\begin{equation}
\begin{split}
\vec{Z}&=\vec{X}+\vec{Y}
\end{split}
\end{equation}Where the probability density function of ##\vec{X}## is given by ##f_{\vec{X}}(\vec{X})## and the probability density function of ##\vec{Y}## is given by ##f_{\vec{Y}}(\vec{Y})##, such that:
\begin{equation}
\begin{split}
f_{\vec{Z}}(\vec{Z})&=\int_{-\infty}^{\infty} d\vec{X} \int_{-\infty}^{\vec{Y}} d\vec{Y} f(\vec{X},\vec{Y})
\end{split}
\end{equation}Where:
\begin{equation}
\begin{split}
\int_{-\infty}^{\infty} d\vec{X} \int_{-\infty}^{\vec{Y}} d\vec{Y} f(\vec{X},\vec{Y})&=\int_{-\infty}^{\infty} d\vec{X} f_{\vec{Y}}(\vec{Y})f_{\vec{X}}(\vec{X})
\end{split}
\end{equation}Given ##\vec{Y}=\vec{Z}-\vec{X}##:
\begin{equation}
\begin{split}
\int_{-\infty}^{\infty} d\vec{X} f_{\vec{Y}}(\vec{Y})f_{\vec{X}}(\vec{X})&=\int_{-\infty}^{\infty} d\vec{X} f_{\vec{Y}}(\vec{Z}-\vec{X})f_{\vec{X}}(\vec{X})
\end{split}
\end{equation}Which is the convolution ##f(f_{\vec{X}}*f_{\vec{Y}})##, such that:
\begin{equation}
\begin{split}
f_{\vec{Z}}(\vec{Z})&=(f_{\vec{X}}*f_{\vec{Y}})(\vec{Z})
\end{split}
\end{equation}
Given:
\begin{equation}
\begin{split}
E_{\vec{Z}}(\vec{Z})=\int_{-\infty}^{\infty} d\vec{Z} f_{\vec{Z}}(\vec{Z}) \vec{Z}
\end{split}
\end{equation}Such that:
\begin{equation}
\begin{split}
E_{\vec{Z}}(\vec{Z})=\int_{-\infty}^{\infty} d\vec{Z} (f_{\vec{X}}*f_{\vec{Y}})(\vec{Z}) \vec{Z}
\end{split}
\end{equation}
\begin{equation}
\begin{split}
\end{split}
\end{equation}
Then E(Z)=E(X)+E(Y). This is a well-known result (and it doesn't even need independence). What is new?
This is technically valid approach, but involves more work than needed.
\begin{equation}
\begin{split}
\end{split}
\end{equation}
Note: The this right here is a convolution. But rather than going through the weeds of the underlying calculations, you can make use of the Linearity of Expectations and find
##E[Z] = E[ X + Y] = E[X] + E[Y]##
\begin{equation}
\begin{split}
\end{split}
\end{equation}
This isn't a convolution... I'm not really sure what it is. The below would be the convolution of the two random variables written out in integral form. But again, using linearity of expectations makes your life a lot easier.
##f_Z(z) = \int_{-\infty}^{\infty} f_X(x) f_Y(z-x) dx##
## \int_{-\infty}^{\infty} z f_Z(z) = E[Z] = E[ X + Y] = E[X] + E[Y]##
Nothing new. I just want to make sure I'm understanding correctly.
In this context, am I correct in the following:
If I want to find the average of two expectation values, such that:
\begin{equation}
\begin{split}
E_{\vec{Z}}(\vec{Z})&=\text{Avg}\left(E_{\vec{X}}(\vec{X}),E_{\vec{Y}}(\vec{Y}) \right)
\end{split}
\end{equation}Do I need to perform a weighted average or can I just assume the following?:
\begin{equation}
\begin{split}
E_{\vec{Z}}(\vec{Z})&=\frac{E_{\vec{X}}(\vec{X})+E_{\vec{Y}}(\vec{Y})}{2}
\end{split}
\begin{equation}
\begin{split}
\vec{Z}&=\frac{\vec{X}+\vec{Y}}{2}
\end{split}
\end{equation}
If your goal is to define Z
such that ##Z := \frac{1}{2} \big(X + Y\big) = \frac{1}{2} X + \frac{1}{2} Y##
then take the expectation of both sides and see
##E[Z] =E[\frac{1}{2} X + \frac{1}{2} Y] =\frac{1}{2} E[X] + \frac{1}{2} E[Y]##
It really is that simple. But you need to be very clear on what your goal is, and define Z accordingly. (The wording in this thread has not been so clear.)
I want to make sure I understand correctly how to find the average of two expectation values. My sense was exactly what you just stated, but I wasn't sure.
By the way, you had a question about the equation:
\begin{equation}
\begin{split}
\end{split}
\end{equation}
I got that from the following source: http://statweb.stanford.edu/~susan/courses/s116/node114.html
Probably should have written it as follows:
\begin{equation}
\begin{split}
f_{\vec{Z}}(\vec{Z})&=\int_{-\infty}^{\infty} d\vec{Y} \int_{-\infty}^{\vec{Y}} d\vec{X} f(\vec{X},\vec{Y})
\end{split}
\end{equation}
There's still a lot of problems with that equation, as you've written it. (Notice that line 1 of the Stanford link is basically how I wrote it.)
You have your ##d## being applied to a vector valued random variable. Ignoring the vector notation, you are using capital letters which denotes the random variable itself and you've applied the "d" to those random variables and are using a random variable as a limit of your inner integral. Lower case letters are specific values that the random variable can take on as in ##X(\omega) = x## or in more common shorthand for each ##X = x##.
I.e. what you wrote is materially different than what's in that link, and from what I can tell it's not well defined.
