What Determines the Force Between Links in a Chain Under Acceleration?
The discussion focuses on calculating the forces between links in a chain being lifted with a constant acceleration of 2.49 m/s². Participants clarify that each link must support not only its own weight but also the weight of all links beneath it, leading to an additive force requirement. The calculation involves considering both the gravitational force and the force due to acceleration for each link. Understanding the mechanics of how forces interact between the links is emphasized as crucial for solving the problem. The conversation highlights the importance of grasping the underlying principles rather than just obtaining numerical answers.
JessicaHelena
In the figure below, a chain consisting of five links, each of mass 0.103 kg, is lifted vertically with a constant acceleration of magnitude a = 2.49 m/s2.
(a) Find the magnitude of the force acting between link 1 and link 2.
(b) Find the magnitude of the force acting between link 2 and link 3.
(c) Find the magnitude of the force acting between link 3 and link 4.
(d) Find the magnitude of the force acting between link 4 and link 5.
(e) Find the magnitude of the force
exerted on the top link by the person lifting the chain.
(f) Find the magnitude of the net force accelerating each link.
I didn't quite know what I was supposed to do, so googled the problem (I'm not really trying to cheat though). I found this https://answers.yahoo.com/question/index?qid=20110322030804AAe7RWU. While I can see how to get each of those answers, I don't understand why you just keep on adding the values. Also, there are many forces acting on each link, so what does the question mean by the force "acting between" certain links? Understanding how to solve probs is more important than just solving them for me, so please help me understand why.
Start by assuming your chain consists only of one link (link #1). Could you explain how to calculate the necessary force to lift it upwards with a constant acceleration of 2.49m/s^2?
JessicaHelena said:
... While I can see how to get each of those answers, I don't understand why you just keep on adding the values.
Think of this: you are hanging on a rope, hands don't hurt much. Now someone grabs your ankles and they are being supported by you. Do you hands feel the same?
Likes stockzahn
@stockzahn — That would be 2.49 * 0.103 + 0.103 * 9.8 (part a)...
@phinds — oh so each time you have one more link, you need the force needed to lift it up at the same acceleration (what stockzahn wanted me to find), and so add it...?
Right. Each link has to support ALL of the links below it
11K
  • · Replies 20 ·
