The inverse of spacetime curvature?
The discussion revolves around the concept of spacetime curvature, exploring whether it can be understood in terms of extrinsic curvature versus intrinsic curvature. Participants examine analogies, such as the trampoline model, to illustrate their points and consider the implications of negative mass on spacetime geometry.
  • Some participants suggest that bending spacetime could be analogous to bending a paper, questioning why spacetime does not deflect lines of attraction towards Earth.
  • Others clarify that general relativity deals with intrinsic curvature, contrasting it with extrinsic curvature, and provide examples to illustrate this distinction.
  • One participant proposes that if spacetime were extrinsically curved, it would be undetectable, as only intrinsic curvature can be measured.
  • There is discussion about the implications of negative mass on curvature, with some suggesting that negative mass could lead to different curvature properties.
  • Several participants engage with the trampoline analogy, debating whether changes in coordinate systems affect the perception of curvature and tidal forces.
  • One participant references a paper by John Baez to discuss the behavior of a ball of dust in a gravitational field, emphasizing volume changes in relation to gravity.
Participants express multiple competing views regarding the nature of spacetime curvature, particularly in relation to intrinsic versus extrinsic curvature and the role of negative mass. The discussion remains unresolved, with no consensus reached on these points.
Some participants note limitations in understanding the implications of extrinsic curvature and the conditions under which negative mass might exist. The discussion also highlights the complexity of measuring curvature in different contexts.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring concepts in general relativity, curvature, and the implications of mass on spacetime geometry.
LilPhysics
Let's say you can bend a paper...how about bending it upward. a slope
I'm saying as we saw spactime in 3d...we all know how it looks..the lines are attracted toward Earth but why doesn't it deflects them and maybe negative mass is linked with it.
In other words, someone under the trampoline pushing you up instead of you bending the trampoline.Instead curving...it deflects
Maybe black holes deflects light through spacetime and hence the problem is what occupies the void of 4D if deflected
That type of bending is called extrinsic curvature. General relativity deals only with intrinsic curvature. If you draw a triangle on a piece of paper then the angles sum to 180 deg regardless of how you fold it.
LilPhysics said:
...someone under the trampoline pushing you up instead of you bending the trampoline...
Someone living within the 2D trampoline sheet wouldn't notice any difference between these two symmetrical cases, because the sheet's intrinsic geometry (distances within the sheet) would be the same. That is what matters in this analogy, not how the curved 2D surface is oriented within the 3D embedding space.
See also:
http://demoweb.physics.ucla.edu/content/10-curved-spacetime
Then what if spacetime deal with extrinsic... Anyone watched the 3D visualized Spacetime curve of earth. You kr what it looked like but what happens when it deflects that's what I'm saying. You might want to google 3d spacetime...what if spacetime is extrinsic also , there must be a link for it with negative mass, -ve mass's inertia is different and so can the curvature be different
here
As John Baez describes here: https://arxiv.org/pdf/gr-qc/0103044.pdf, the content of Einstein's theory of gravity can be understood in terms of what happens to a ball of dust, initially spherical and initially at rest in some locally inertial reference frame. If you release this ball in a gravitational field, its shape will be warped; it will become stretched in some directions and compressed in other directions. If the ball is in outer space, and is not passing through any matter (or energy), the volume will remain unchanged. It doesn't matter that there might be a gravitational source outside the ball; if the ball passes near the Earth, its shape will change but its volume will not. But if there is a source of gravity inside the ball, then the volume will contract. The fact that there is no negative mass means that if the ball is in freefall (no forces acting on it other than gravity), its volume can only contract or remain the same through interaction with gravity, it can never expand.
We would have no way to notice any difference.
As @jbriggs444 mentioned, if spacetime is extrinsically curved in some higher dimensional embedding space then we would never know. All that we can detect is the intrinsic curvature, there is no way, even in theory, to measure the extrinsic curvature.
Edit: just noticed this
No need to bring in extrinsic curvature here. Positive mass leads to positive intrinsic curvature (triangle has >180 deg). Negative mass leads to negative intrinsic curvature (triangle has <180 deg). Or at least it does if it exists, which is doubtful.
Regarding the trampoline example, being pushed up or pushed down, am i to understand that since a simple change of coordinates can make the two situations identical (i.e., reverse the positive direction on your axes and suddenly “up” becomes “down”), then there isn’t any “curved spacetime,” that is, no tidal forces that are present in one situation but not the other?
Yes. It is an obvious isometry. However, that is not to say that there is no curvature. It is to say that the intrinsic curvature is identical in the two cases.
The trampoline has intrinsic curvature, but it represents space, not spacetime.
Thanks guys a lot, btw I'm just a student about to sit for A level exams and it's my first year plus physics is DOPE
  • · Replies 27 ·
  • · Replies 25 ·
  • · Replies 0 ·
