The magnitude of the vector difference , is closest to
The discussion focuses on calculating the magnitude of the vector difference B - A using given vector components. The user initially calculated the magnitudes of vectors A and B separately but arrived at an incorrect difference. The correct method involves subtracting the vector components directly, taking into account their directions. The final magnitude of the vector difference should be calculated using the resultant components. The correct answer for the magnitude of the vector difference is 16.
Mdhiggenz
The components of vectors and are given as follows:
Ax = +5.7 Bx = -9.8
Ay = -3.6 By = -6.5
The magnitude of the vector difference ,B-A is closest to:
A=square root (ax)^2+ay^2
B= square root (bx)^2 + by^2
Pretty much what I did was get the magnitude for A by using the above formula, and for A I got 6.7 and for B I got 11.79, I then subtracted B-A to get 5.0. However the answer is 16 I don't understand how that can be the case.
Thank you
You forgot to account for the direction of the vectors.
To get the difference between two vectors, you subtract the vectors head-to-tail.
In terms of components:
D = B - A = (Bxi + Byj) - (Axi + Ayj)
what is |D|?
10K
9K
  • · Replies 25 ·
