The Mysterious, Impossible Box: Questions & Answers
  • Context: High School
  • Thread starter Thread starter mrpeach32
    Box Impossible
The discussion revolves around a hypothetical scenario involving a perfectly reflective box containing a lamp that generates light without interference. Participants explore questions related to the mass of the box, the potential for it to "pop," and the behavior of light within this impossible setup. The conversation touches on theoretical implications and conceptual challenges rather than practical applications.
  • Some participants suggest that the box would gain mass due to the energy of the photons, which can be interpreted through relativistic principles.
  • Others question the definition of "pop," with some interpreting it as the box shattering due to photon momentum impacting the walls.
  • There are differing views on whether the box would radiate heat before breaking, with some arguing it would heat up and potentially break down the reflective surface.
  • A few participants discuss the implications of photon density amplification and relate it to laser technology, noting that this scenario has been of interest in physics.
  • Some express skepticism about applying classical Newtonian physics to photons, suggesting that this leads to nonsensical results.
  • One participant raises the point that while photons are massless, an increase in their concentration might not lead to an increase in the mass of the box itself, but could affect pressure and temperature.
  • There are repeated inquiries about the nature of mass and weight in the context of the box and its contents, leading to further clarification and debate.
Participants do not reach a consensus on the implications of the scenario. There are multiple competing views regarding the mass of the box, the meaning of "pop," and the behavior of photons within the box, indicating that the discussion remains unresolved.
Limitations include the hypothetical nature of the scenario, the dependence on definitions of mass and weight, and unresolved questions regarding the energy dynamics of photons in a closed system.
mrpeach32
Lets say you had a box who's inside walls were perfectly reflective. In addition to this, because you are just so very awesome, you are somehow able to put a lamp inside that box that doesn't interfere with and of the light rays in the box except to produce more. Now since this is a silly and impossible set up, I'm going to ask some silly and ridiculous questions about it.
1) Would the box get more massive?
2) Would the box eventually have to "pop?"
3) If it was broken open, would there be a flash of light before it dissipated?
I welcome answers, more questions related to this, and snide comments about how pointless it is to wonder about these things.
Science news on Phys.org
There's really no such thing as perfectly reflective. Eventually the walls will absorb photons and heat up.
How is your lamp powered? If there's no way in for electricity, then the light will eventually stop. If it's battery-powered then you're putting all the "ingredients" for the photons in the box before you close it.
The entire idea was based out of it being completely impossible, really. I was just wondering whether it was possible to "fill" something up with light if certain conditions were met. So at the risk of sounding, well, stupid, I guess I don't really know what the lamp is powered by. Maybe this question is a bit too hypothetical for realistic consideration :-D
The following is from: http://en.wikipedia.org/wiki/Total_internal_reflection
"Total internal reflection is an optical phenomenon that occurs when a ray of light strikes a medium boundary at an angle larger than the critical angle with respect to the normal to the surface. If the refractive index is lower on the other side of the boundary no light can pass through, so effectively all of the light is reflected. The critical angle is the angle of incidence above which the total internal reflection occurs."
----------------------- And further in the article:
"Total internal reflections can be demonstrated using a semi-circular glass block. A "ray box" shines a narrow beam of light (a "ray") onto the glass. The semi-circular shape ensures that a ray pointing towards the centre of the flat face will hit the curved surface at a right angle, this will prevent refraction at the air/glass boundary of the curved surface. At the glass/air boundary of the flat surface, what happens will depend on the angle. Where θc is the critical angle (measured normal to the surface):
If θ < θc, as with the red ray in the above figure, the ray will split. Some of the ray will reflect off the boundary, and some will refract as it passes through.
If θ > θc, as with the blue ray, the entire ray reflects from the boundary. None passes through. This is called total internal reflection."
Just something to offer your question.
1)yes
2)what does 'pop' mean?
3)yes
A laser cavity is light-in-a-box, when supplied with both mirrors fully reflective.
It is also important to note that your type of question/scenario is one that has been and continues to be of considerable interest.
For example, at 50% efficiency, a 1 second pulse of photons contained as such and then released at one time(in-phase or not) in one direction, will effect a photonic impact pulse 90,000 times that of the initial input.
Of course, the pulse will necessarily be 90,000 times shorter in pulse-length.
Basically, this is photon density amplification, and should not be confused with a laser, though lasers are often used for the initial pulse.
On a related note, have you ever had one of those plastic "neon" hand-held clipboards, which emit a very bright light from its edges even in low-light surroundings? Doesn't work in total darkness of course.
This is due to internal reflectance from ambient light on the 2 flat surfaces, then exiting the edges.
Not "perfect" internal reflectance or efficiency, but quite remarkable.
I have one here as we speak.
Phrak said:
1)yes
3)yes
1) How does it get more massive, because the energy of the photons can be seen as mass in a relativistic view or something?
2) I think by 'pop' he means that the box shatters or breaks. I would have to say yes, because photons do carry momentum. If you have a large number of photons bouncing off the walls of a box the walls will be pushed outwards by a tiny amount. If you just put in enough photons they would eventually break, depending of course on how much they can take. Note that the momentum of photons is very small and you would need a hell of a lot of photons to achieve this...
I wouldn't break, it would just start radiating heat as the impacts started heating the walls. If it couldn't radiate fast enough, it would eventually break down whatever the reflective surface is made of.
In this way: m=F/a. Put it on a scale, it weights more. Try to push on the box, it has more inertia. And in this way: m^2=p^2 for a standing wave. (odd, that it wouldn't work for massless fermions)
I wouldn't have to say its completely pointless...its sort of like shifting the open end of the box so that the Sun is contained in it, then closing the open part...
Well ok, but I guess you could see that last thing as the box breaking no?
Weight is not the same as mass though... If you put the box on a scale and press down on it that wouldn't make the box more massive, but it would make the scale read a larger value.
Why?
I'm not trying to say it's not going to be more massive (for all I know it could), I just don't completely understand how.
Yeah, I'm not exactly convinced of this.
Convinced of what?
Phrak said:
Convinced of what?
You can't apply classical Newtonian physics to photons and get sensical results.
That's worth thinking about.
By the way, I can't believe I screwed that up. p=0, so that E^2=m^2
Just my 2 cents, but if photons are massless particles, how can an increase in their concentration cause an increase in mass?
I would think the box would see an increase in pressure and temperature but not an increase in mass?
What, if not mass, is responsible for the deflection of the scale?
You have a 2 kilo, ideally reflective box, containing 10 kilo of matter and 10 kilo of antimatter. It is suspended by a balloon capable of lifting 7 kilo. Placed on a scale, the scale reads 15 kilo. You enable the contents to annihilate. The scale still reads 15 kilo.
Let's imagine for a moment that the mass of the contents vanishes to zero upon annihilation. The balloon lifts the box and an additional weight to some astonishing altitude. Some means is provided to return the box to it's initial state. It decends, and the process is repeated, where another weight is lifted.
Now we can object, and say that the annihilation process is thermodyamically irreversible and the box will not decend. This places us in the position of claiming that conservation of energy is a result of the second law; we would making the interesting claiming that energy is only statistically conserved.
The force that the photons exert on the walls of the box.
(But now I think about it, on average that force would be zero so the weight of the box would not increase).
Anyway as I've said, weight and mass are two different things. Your weight can increase while your mass does not. The topic starter (and me) asked about the mass, not the weight.
Mass and weight are two different things, this is correct. Weight is relative. For example, something with a certain mass will have a a different weight on the moon than on the earth. Although the mass does not change, the weight does. In this case, weight is relative to gravity.
Actually, the force is greater on the bottom of the box than the top.
Of course, that's not the issue. How is mass defined? How is mass measured?
Because of gravity? Or why would it be greater?
But it is an issue here (at least for my question): The weight of the box can increase due to the force of the momentum of the photons, but at the same time, it is perfectly fine for the mass to stay the same. So is the mass changing, or is the weight changing (and the mass not changing)?
Maybe look at it this way...
Place a 1 lb. block of steel on a bathroom scale. Let it stabilize.
Now drop from, say, a height of 3 feet a standard baseball onto that steel block.
Notice that the scale will increase it's "reading" during impact, and that the peak reading exceeds a reading of a different scenario... where the the baseball is gently placed on top of the steel block(as opposed to being dropped from 3-feet).
I hope I'm not confusing you here.
Because of gravity. The light at the bottom of the box has a higher frequency as verified by the Mossberg Effect. Any photons with vertical trajectories will recoil from the bottom surface of the box with a greater change in momentum than those photons impinging on the top of the box.
Horizontal trajectories will be bent downward.
The more light that is confined to the box, the more it will weigh on the scale. The light in the box plus the box has ponderable mass greater than the empty box alone. It has inertia greater than the empy box alone.
It might come easier to you if you forgot about gravity and just accellerated the box in free space.
Every body continues in its state of rest, or of uniform motion in a right [straight] line, unless it is compelled to change that state by forces impressed upon it. -Newton
We can replace state of rest or uniform motion with the 'freely falling', and 'right line' with the geodesic of general relativity, and it remains true, when gravity is removed as a force.
I can't think of any reason why the light by itself, considered as a system, doesn't have inertial mass, except that it requires the presence of the box for the system of radiation be as massive as it is.
DaveC.
I've found a way to eliminate the Newtonian elements. In fact, it's an old thought experient of '97 or so. Little did I know that moving it to a scale would clutter the problem.
Consider a massless box contains equal parts matter and antimatter in orbit (freely falling). Upon annihilated, will the box acquire a rectilinear trajectory, remain in it's original orbit, or something else?
It is pointless to wonder about such things. :devil: You should spend your time more wisely by reading this paper, so you can explain it to me. :-p
"let us imagine confining the beam to a mirrored box"
Carlip, Kinetic Energy and the Equivalence Principle
http://arxiv.org/abs/gr-qc/9909014
I'll read it.
Where is the momentum found in the electromagnetic field equations, do you know?
I only understand the flat spacetime case. The EM energy-momentum tensor is [tex]T_m_n = -F^a_mF_a_n + \frac{1}{4}g_m_nF^a^bF_a_b[/tex]. In flat spacetime, with cartesian coordinates, [tex]T^0^m[/tex] are the components of the Poynting 3-vector S=EXB, which I guess is the intuitive momentum.
For light in a box, flat spacetime should be sufficient. I was looking at the Ponyting vector myself. So for a planar wave of directionally polarized light, the Poynting vector propagates in longitudinal waves. For circularly polarized light S is constant in magnitude.
For standing waves...
He he, I never thought of that. I can't resist putting down my guess: it propagates to the nodes and cancels out there? Let us know when you figure out the right answer.
  • · Replies 42 ·
  • · Replies 24 ·
