The philosophy of squaring > Why no f=ma^2
  • Context: Undergrad
  • Thread starter Thread starter MinnesotaState
    Philosophy
The discussion centers on the fundamental differences between force and energy, specifically addressing the equation F=ma and the misconception surrounding the idea of F=ma². Participants clarify that force is defined as mass multiplied by acceleration, while energy is represented by E=mc², which is an incomplete representation of energy in motion. The conversation highlights the philosophical debate regarding the definitions of physical quantities and their historical context, emphasizing that understanding these concepts is essential for grasping the principles of physics.
  • Understanding of Newton's Second Law (F=ma)
  • Familiarity with the concept of energy and its equations (E=mc²)
  • Basic knowledge of classical mechanics and motion
  • Awareness of historical debates in physics, particularly between Leibniz and Cartesian views
  • Research the historical context of Newtonian mechanics and its evolution
  • Study the differences between kinetic energy and potential energy
  • Explore the implications of E=mc² and its complete form E²=m²c⁴+p²c²
  • Investigate the philosophical implications of definitions in physics and their historical changes
Students of physics, educators, and anyone interested in the foundational concepts of force and energy, as well as the philosophical discussions surrounding their definitions and implications in the field of physics.
MinnesotaState
Please watch 05:00 to 08:00
Force = Mass x Acceleration
So for example,
F=10 grams x 3 acceleration
What that really means is,
F=10 grams x 1 acceleration
So for every X amount of mass, you get X amount of acceleration. There's a relation here. The amount of mass you get for every acceleration is constant. It has to be. That's the logic behind multiplication. If you have 3 balloons, & multiply them by 3, you get 9. Because 3 x 1 + 3 x 1 + 3 x 1 = 9. If 3 x 1 didn't always equal 3, then the equation would collapse.
Let's go back to the example,
F= 10 grams x 3 acceleration = 30
If I double the mass, I get 20 grams. So, 60.
If I double the acceleration, I get 6. So, 60.
I'm not seeing this "building up of squares."
Leibniz was convinced that the energy of an object was made up of it's mass x it's velocity, squared
So why no f=ma^2
I guess I don't understand the difference between energy & force.
F = ma because this is how the nature works. We can measure this. We can also derive this from some other principles, which may be regarded as more general, and we can again establish experimentally that those principles hold independently. So F = ma is a physically true statement any way you look at it. The question such as "why no f = ma^2" then has a simple answer: because that is not true.
You're basically asking: why is a definition defined to be what is given in the definition? This is of course a pointless question.
Where am I going wrong with energy & force?
They are different,
e=mc^2
f=maI do not understand the philosophy of squaring either.
They are different,
e=mc^2
f=ma
First off, e=mc^2 is not true (at least not complete). The real equation is
E^{2}=m^{2}c^{4}+p^{2}c^{2}
which when p=0, is equal to the Hollywood equation.
I also don't see how the equations are related it anyway, other than both being equations in physics.
If I drop a ball from the empire state building, what will be the force 5 ft from the tip assuming mass of 10 grams.
If I drop a ball from the empire state building, what will be the energy 5 ft from the tip assuming mass of 10 grams.
Now,
If I drop a ball from the empire state building, what will be the force 5 ft from the ground assuming mass of 10 grams.
If I drop a ball from the empire state building, what will be the energy 5 ft from the ground assuming mass of 10 grams.
I still don't see any building up of squares with force as leibniz proposed.
& energy, well acceleration is irrelevant because e=mc^2 is assuming at rest?
Yes. They are nowhere close to the same thing.
They are different...
[separate post]
Huh? An object in free fall isn't exerting any force on anything other than on the Earth due to its weight. This line of discussion is a bit odd because while it is common for people to not understand what energy is, it is not common for people to not understand what force it. Force is just what you feel on your hand when you push something or what a table "feels" when a book is sitting on it. A book sitting on a table is not expending energy because it isn't moving.
I'm picturing people standing at 10 ft intervals from the bottom of the empire state to the tip. This free falling object is slamming into each one of these individuals. Well theoretically.
What happens when it hits the first one? Does it stop?
Again, since energy is not directly related to force alone, trying to relate energy to force in this way is mostly an exercise in futility. The question is not unlike asking how "car" and "white" are related. My car is going 60 mph. What color is it?
When the object slams into them, does it slow down? By how much? That change of speed is acceleration, caused by an individual person applying a force on the object and the object applying an equal and opposite force on the person.
Worse, mechanical energy is not conserved in such a situation, so analysis using energy isn't optimal.
[edit] It is really best at first attempt to look at energy and momentum as just bookkeeping concepts. Just relationships between "more real" quantities that some scientist once upon a time discovered was useful to use in calculations.
Thank you for your responses. I found what I was looking for here,
"If you hold a ball from the top of the empire state building, that ball has something called gravitational potential energy. This means that the ball, because of its position in Earth's gravitational field, has the capability to release a certain amount of energy that is proportional to it's height."
How is it a pointless question? Are you saying it's pointless to ask why definitions are as they are?
Never get into an argument with a philosopher. Neither of you will get satisfaction, and the argument never ends.
Wrong forum but...
the joy of philosophy is the argument.
seeking satisfaction is very satisfying.
When the argument ends it could be called Physics...
As I say...wrong forum
Can we go over the philosophy of squaring?
The philosophical debate between Leibniz and the Cartesians was not about the absurd idea of "building up of squares", but about the conserved quantities of motion and the meaning of the concept "force", which, back in the day, had no common understanding, as it does today.
Here is an article that highlights the issues: http://nature.berkeley.edu/departments/espm/env-hist/articles/2.pdf
If you don't mind me saying so, this is a somewhat arrogant response to a question.
'Definitions' have changed over time (second, metre etc, etc) and the reasons for these changes are part of the history of physics (not philosophy).
In a physics forum worth it's salt we should welcome such questions and think carefully about what lies behind them and where they fit in the story of physics.
Clearly the discussion here shows that he question was not 'pointless'
WOOT WOOT!
Thanks!
We take a physically meaningful quantity that arises naturally out of experiment and decide to label/define it as 'net force'. Asking why this label doesn't stand for something else is pointless, it's just a label. The important part is that the quantity represented by it is tied to something physically meaningful. There's a difference between asking "why should we care about this quantity at all?" and "why not arbitrarily redefine this quantity to something else and call that net force?".
It took a few centuries for that physically meaningful quantity to arise naturally out of experiment.
That much is true, but it takes some culturing to be able to see that difference and not be carried away by pop sci movies featuring extravagantly dressed actors and actresses.
Certainly, there's no denying that.
:smile: Morgan Freeman is the man indeed.
Here is an interesting electrical example for you:
2 circuits, they look identical. Each circuit has a box labelled 'power supply' and 2 other boxes connected in series to their respective power supply. In circuit 1 the boxes are labelled A and B, in circuit 2 they are C and D.
You measure the voltages Va and Vb in circuit 1 and find that they are 2V and 3V. You guess that the supply voltage Vs is 5V... and you are correct!
You now measure Vc and Vd and find that they are 3V and 4V.
You guess that the supply voltage is 7V and you are wrong! it is 5V.
In the first circuit 2 and 3 add to give 5, in the second circuit 3 and 4 add to give 5.
If you are familiar with AC circuits you know the explanation.
however you look at it, in the second circuit the voltages need to be squared to give an answer.
As soon as you see 3+4 = 5 I hope you want to draw a right angle triangle.
With this insight you can formulate (practically) all of the relations in AC theory without meeting sine waves or complex numbers.
This is all based on squaring quantities to deal with them
Because the answer to a definition is always the same and there is nothing philosophical about it: someone noticed that the thing was useful and gave it a name. That's it. That's all the "why" of energy is.
Definitions of values are different from definitions of concepts.
I know.
My issue was with rating someone's question as 'pointless'
There has been some interesting discussion around an apparently 'pointless' question.
The 'silly' question is the first intimation of some totally new development
technician said:
I know.
Frankly, this thread has baffled me from the beginning and I've seen very little value in spending so much time trying to explain something so basic as what force is.
I rest my case.
I only come here when I know I have spare time.
If you want a textbook lesson in how not to do it check this thread...now closed
https://www.physicsforums.com/showthread.php?t=703041
SteamKing said:
I rest my case.
And I mine.
  • · Replies 30 ·
