The Pressure Distribution in a Narrowing Tube with Increasing Fluid Velocity
The discussion centers on the relationship between fluid velocity and pressure in a narrowing tube. As the diameter of the tube decreases, the fluid's velocity increases due to the principle of conservation of mass, expressed as A1V1 = A2V2. This increase in velocity results in a decrease in pressure according to Bernoulli's principle, which states that an increase in the speed of a fluid occurs simultaneously with a decrease in pressure. The participants clarify that while the fluid accelerates, the net force acting on it must also be considered to understand the pressure dynamics fully.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation
  • Knowledge of Newton's laws of motion
  • Familiarity with the concept of pressure as Force/Area
  • Basic mathematical skills for manipulating equations related to flow rate
  • Study Bernoulli's equation and its applications in fluid mechanics
  • Learn about free body diagrams and their role in analyzing forces in fluid flow
  • Explore the concept of kinetic energy in relation to fluid velocity and pressure
  • Investigate real-world applications of fluid dynamics in engineering, such as pipe flow and aerodynamics
Students studying fluid mechanics, engineers working with fluid systems, and anyone interested in the principles of pressure and flow in narrow conduits.
Johny Prime
Question:
For a fluid flowing within a horizontal tube, if the diameter of the tube narrows, will the fluid's flow rate increase, resulting in increased pressure in the narrowing and explain your reasoning.
Volume flow rate = volume/time
Volume = Area x Distance
Velocity = Distance/ time
Sub in Volume = A x D
So, Flow rate = (Area x distance)/time
simplifies down to Flow rate= Area X Velocity
As the volume flow rate is constant, (A1 xV1 = A2 x V2)
if Area gets smaller (the tube narrowing) then Velocity must increase (water goes faster)
What I do not understand, is how does this affect the pressure? Is it to do with Kinetic energy?
Could someone please explain why it results in higher pressure?
Thanks
Think about a parcel of the fluid entering the narrow section. If it is to gain speed, how is that to happen, according to Newton?
I'm not quite sure what you mean, is it because the fluid is going faster and exerting more force on the inside walls of the tube?
What, according to Newton, makes a mass move faster, or change velocity at all?
A force, right? So that means that there's more force acting on the same area and that would increase the pressure since Pressure = Force/ Area?
Would that be correct? I think I'm seeing the connection now.
Getting there, but draw yourself a free body diagram for the parcel of water. It is in the middle of the flow, say, in the narrowing part of the tube, so it is accelerating. Which way is the net force acting?
The net force would be facing the way that the fluid is flowing, right?
The net force would be facing the way that the fluid is flowing, right? The fluid is moving in that direction right?
For it to be getting faster, yes. What does this tell you about pressures?
The pressure would have to increase, right? If it's going faster, then there's Acceleration so according to the formula: Force = Mass X Acceleration, Acceleration is increasing and that would mean that Force is increasing, which would result in Pressure going up via the formula Pressure = Force/ Area. Is that sound enough explanation to answer the question fully?
No. You drew a free body diagram of the parcel of water, yes? You can draw it as a cube. Say the tube it is in is narrower to the right and it is accelerating to the right. Where on the cube is the greatest pressure?
  • · Replies 19 ·
