The space shuttle is in a 300 km-high circular orbit
The discussion focuses on calculating the energy required for the space shuttle to transition from a 300 km circular orbit to a 610 km circular orbit. The relevant equation used is the gravitational potential energy formula, specifically dPE = GMm * (1/(r+h1) - 1/(r+h2)), where G is the gravitational constant, M is the mass of Earth, and m is the mass of the shuttle. The final calculations yield approximately 2.1 x 10^11 J using both the potential energy formula and the simplified mgh approach, confirming that both methods provide consistent results for the energy required.
  • Understanding of gravitational potential energy equations
  • Familiarity with the gravitational constant (G)
  • Basic knowledge of orbital mechanics
  • Ability to perform calculations involving significant figures
  • Study the derivation and applications of gravitational potential energy equations
  • Learn about the implications of orbital mechanics on satellite positioning
  • Explore the concept of energy conservation in space travel
  • Investigate the effects of altitude on gravitational force
Aerospace engineers, physics students, and professionals involved in satellite operations or space mission planning will benefit from this discussion.
mookie84
The space shuttle is in a 300 km-high circular orbit. It needs to reach a 610 km-high circular orbit to catch the Hubble Space Telescope for repairs. The shuttle's mass is 7.00×10^4 kg.
½(-G(M-earth)(M-telescope))(1/r2 –1/r1)
G=6.67*10^6
Mass of earth=5.98*10^24
Mass of telescope= 7.0*10^4 kg
Radius of earth= 6.98*10^6 m
What I did was plug in the numbers to the equation. For r2 I added the radius of Earth + the height needed to be attained (610km). For r1 I added the radius of Earth plus the original height (300km). I keep getting 8.4*10^10 which is the incorrect answer. What am I doing wrong?
what is the question?
Sorry about that?
How much energy is required to boost it to the new orbit?
The difference in height is small compred to Earth's radius - what does "m g h" give?
which mass are you referring too? Earth or the satellite?
The shuttle - it's just the same question as lifting a weight on earth.
I've tried that it doesn't work. The question is asking me how many joules does it take to move the satellite from 310 km above the surface of Earth to 600 km. When i tried the equation you offered I'm neglecting the Earth's radius and mass which affects the gravitational pull
You are taking the radius and mass of the Earth into account in the factor 'g'
g = GM_earth/r_earth^2 = 6.67E-11 * 6E24 / (6.4E6 ^ 2) = 9.8 m/s^2
Potential energy is GMm/r so for the difference in height of 300km and 610km we have
dPE = GMm * ( 1/(r+300km) - 1/(r+610km) )
= 6.67E-11 * 6E24 * 7E4 * ( 1/(6370,000+300,000) - 1/(6370,000+610,000) )
= 6.67E-11 * 6E24 * 7E4 * 6.6E-9 = 1.8 E 11 J
or assuming change in gravity between 300km and 610 km is small and mass of shuttle is small compared to earth.
= m g h = 7E4 * 9.8 * 310,000 = 2.1 E11 J
Since the mass of the shuttle is only given to 1 sig figure the answer 2E11J is the same for both.
  • · Replies 27 ·
