The total voltage drop in a series RLC circuit
  • Context: High School
  • Thread starter Thread starter mymodded
    Circuit Rlc Voltage
The discussion revolves around the total voltage drop in a series RLC circuit, specifically questioning the validity of the equation relating the total voltage to the individual voltage drops across the resistor, inductor, and capacitor. Participants explore concepts related to Kirchhoff's Voltage Law, phasor representation, and the implications of using maximum versus instantaneous voltages.
  • Some participants question whether the total voltage across all components in a series RLC circuit is truly equal to the sum of the individual voltage drops, ##v_{L} + v_{C} + v_{R}##.
  • One participant asserts that Kirchhoff's Voltage Law supports the idea that the loop voltage must equal the sum of individual voltage drops, suggesting confusion over scalar versus complex voltages.
  • Another participant describes a scenario where the inductor's voltage was calculated to be significantly higher than the source voltage, raising questions about the validity of the first equation in light of the second equation, ##V_{m}^{2} = V_{R}^2 + (V_{L} - V_{C})^{2}##.
  • There is a discussion about whether the second equation holds true for instantaneous voltages rather than maximum voltages, with references to phasor vectors and RMS values.
  • Some participants highlight the importance of considering the phase of each voltage term when summing voltages in AC circuits.
  • One participant suggests reviewing voltage dividers, complex impedance, and phasor representation for further understanding.
Participants express differing views on the validity of the equations related to voltage in a series RLC circuit. There is no consensus on whether the total voltage drop can be accurately represented by the sum of the individual voltage drops, and the discussion remains unresolved with multiple competing perspectives.
Participants note that the equations discussed involve assumptions about voltage types (instantaneous vs. maximum) and the implications of using RMS values in AC circuit analysis. The relationship between voltage drops and gains in the context of Kirchhoff's Voltage Law is also highlighted, but remains a point of contention.
mymodded
TL;DR
is the total voltage across all components in a series rlc circuit really equal to ##v_{L} + v_{C} + v_{R}## ?
my textbook said this
which I don't think is true, tho the textbook still said this (this equation is the true one)
so is the textbook right about the first equation?
figure 10.15figure 10.16
mymodded said:
TL;DR Summary: is the total voltage across all components in a series rlc circuit really equal to ##v_{L} + v_{C} + v_{R}## ?
Why not? The loop voltage is the sum of the individual voltage drops (and any voltage gains). How can it be otherwise? Are you trying to ask about scalar versus complex voltages somehow?
BTW, your posting of math as images is making it hard for me to quote parts of your post that I want to focus on. I will send you a PM with hints on using LaTeX at PF to post math equations. Please start using LaTeX instead of images as soon as you can. Thank you.
yes. Look into Kirchhoff's Voltage Law.
Why? Please explain what is confusing you. Otherwise we don't really know how to give useful answers.
Imagine you have a voltmeter and you fix the - probe at a circuit node. Then you start with the + probe at that node (where is should say zero) and sequentially move around the loop. When you get back to the starting point would you expect the voltage to be zero? doesn't that mean that the voltages all sum to zero? If not where would the extra voltage be?
Don't be confused by time varying signals. The Kirchhoff's Voltage Law applies at each instant in time.
Khan Academy has some really good electronics tutorials. I would check those out if I was you.
there is a question where we had to solve for the inductor's voltage which turned out to be about 500V, even though the AC source was only 12V and the only reason it made sense is because ##V_{m}^{2} =V_{R}^2 + (V_{L} - V_{C})^{2}## and ##V_{C}## was equal to ##V_{L}## (at resonance), so they cancel out, I don't know how the first equation holds true when the second equation holds true as well. Or it could be that it has something to do with one of them being a voltage drop while the other is a voltage rise. Also if the first equation ##V = v_{C} + v_{L} + v_{R}## is true, why do we have the second equation?
edit: I've got a question, in the equation ##V_{m}^{2} =V_{R}^2 + (V_{L} - V_{C})^{2}##, ##V_{m}, V_{R}, V_{L}, V_{C},## correspond to the maximum voltages, but does this equation hold true when the actual voltages (I mean when they are not at their maximum) are used instead of the maximum voltages? I know this equation is derived from adding the phasor vectors but I'm just wondering.
The KVL equation ## v_{C}(t) + v_{L}(t) + v_{R}(t) = v_{S}(t)## has instantaneous voltage terms. So, in your example ##v_{S}(t) = 12 \sqrt{2} sin(\omega t)##, etc. The ##\sqrt{2}## factor is because it's common to use RMS voltages when describing AC sources, but you could leave it out and just refer to peak magnitude.
The other equation ##V_{R}^2 + (V_{L} - V_{C})^{2}## is a calculation of the magnitude squared of the voltage sum. So, for example ##|v_{S}(t)| = |12 \sqrt{2} sin(\omega t)| = 12 \sqrt{2} = V_{S} ## or 12Vrms. Then ##V_{R}^2 + (V_{L} - V_{C})^{2} = |v_{R}(t) + v_{L}(t) + v_{C}(t)|^2##. Of course the phase of each voltage term matters when you add them up.
Thank you so much appreciate it a lot
But wait, ##|v_{R}(t) + v_{L}(t) + v_{C}(t)|^2## is not necessarily always equal to the peak squared while ##V_{R}^2 + (V_{L} - V_{C})^{2}## appears to always equal the peak squared (as it uses the maximum voltage for each component) so how is that so?
Sorry, I'm working and traveling for a few days. Plus I find your last question a bit confusing, which makes it hard to answer. I suggest you review voltage dividers, complex impedance, and phasor representation of AC circuits. Khan Academy has some really good material on this. Maybe others will step in to help?
The solution process will go like this:
Find the loop current by adding the impedances (including their phase) across the source.
Then find the inductor voltage by multiplying that current by the inductor impedance.
So, the voltage gain ##\frac{V_L}{V_S} = |\frac{j \omega L}{R+j \omega L+\frac{1}{j \omega C}}|##
Also note that ##V_L = | j \omega L⋅ I|##, etc.
Which textbook do you refer to?
The term ##|v_{R}(t) + v_{L}(t) + v_{C}(t)|^2## is the square of the instantaneous total voltage at time ##t##.
The overall complex impedance can be written as
## \underline {Z} = R +jX##
with ##R## = resistance and ##X## = reactance.
It follows the absolute value of the complex impedance:
##\left | \underline Z \right | = \sqrt{R^2 + X^2}##.
For a series LCR circuit a good way of analysing it is to first assume a current of 1 Amp. This is the same everywhere in the circuit. Then find the reactances, XL and XC. If 1 amp is flowing in a reactance of say, 10 Ohms, then the voltage across it is 10 volts. You can draw a phasor diagram where I is the reference and VX is then drawn leading it by 90 degrees and VC is lagging it by 90 degrees. VR is in phase with the current. It is then a simple matter to add the three voltages vectorially and find the voltage across LCR.
For a parallel LCR circuit, we assume a 1 volt generator, so we have 1 volt across each element, and find the currents in each element in a similar way as I have described.
I refer to this textbook [PDF link redacted by the Mentors due to Copyright violation] (you can find this lesson on page 274 in the pdf or 267 in the actual book), they don't usually do this, but I feel like they missed out on many pieces of information in this unit.
The term ##|v_{R(t)}+v_{L(t)}+v_{C(t)}|^{2}## is the square of the instantaneous total voltage at time t.
thanks a lot!
  • · Replies 22 ·
  • · Replies 32 ·
