The typical and the exceptional in physics
445 replies · 33K views
Demystifier said:
If we accept the instrumental interpretation according to which there is no wave function of the universe, then, in the same interpretation, there is no density operator describing the whole LHC.
This does not follow. The only obstacle to interpreting the wave function of the universe in the Copenhagen interpretation is the lack of an outside observer.
But the LHC is actually observed from the outside, and consists of a finite number of massive particles only, hence even has a description in nonrelativistic quantum mechanics with relativistic correction terms. You forgot to demonstrate why in this description the LHC has no state!
Demystifier said:
Of course, you are free to use a different interpretation, but then your interpretation is not the minimal instrumental interpretation advocated e.g. by Peres..
Of course, I could use my thermal interpretation. But even in the minimal interpretation, there are enough observable copies of the LHC (namely the single LHC shifted in time) so that one can apply the minimal interpretation in the form of Peres, independent of Copenhagen.
Demystifier said:
In the operational interpretation of QM, insertion of the middle polarizer (or any other polarizer) should be viewed as a choice of the effective time-dependent Hamiltonian. The Hamiltonian defines the corresponding Schrödinger equation, so any change induced by insertion of the polarizer should be viewed as evolution by Schrödinger equation.
In other words this measurement is not just update of information about photon polarization, right?
What I wanted to say is that, in practice, most of LHC is described by classical physics. Therefore, in practice, one cannot associate a quantum state with it.
Insertion of the polarizer is not an update at all. To update the information, you must also have a detector (polarizer is not a detector) and take a look at it.
The measurement consists of a polarizer and a detector, but measurement is not yet an observation. Observation needs a conscious being who will look at detector. Only the conscious being (with some knowledge of QM) can do the update.
What I wanted to say, however, is that there is no theoretical obstacle to describing all of the LHC by quantum mechanics. Thus one can associate a quantum state with it, though in practice it is only poorly known. But one can translate every classical knowledge about it into a corresponding Wigner density operator, so that even in practice one could give a reasonable density operator for it.
In any case, for the foundational discussion here it doesn't matter whether one can specify the state in practice but only that it exists.
A computer program written by a conscious being with some knowledge of QM can do the update, too. Just as the classical models of the stock market are automatically updated by computer programs. Thus consciousness is in no way involved in the collapse.
zonde said:
Yes, I used poor wording. I should have said "physical change of subensemble that is described by wave-function".
In terminology of post #126, do you mean physical 1 or physical 2?
When we analyze experimental setup we imagine that we have a detector at the place where we describe wave-function. A suppose that it goes without saying.
Now you are changing my terminology which I fixed in post #154. Without fixing the meaning of words it's very hard to have a meaningful discussion. In #154 I fixed the terminology in a way that would please @vanhees71, but it's impossible to fix terminology in a way that would please everybody.
Yes, I agree with that. But instrumental interpretation of QM does not care much about what is possible in principle. In principle it is possible to eat with a hammer, but it is irrelevant for both a repairman and a waiter.
physical 2, but with addition that physical change means that there are no subjective aspect of it (no observer will say "nothing happened")
A. Neumaier said:
The collapse means taking probabilities conditioned on the known observations. Thus it is included in my axioms. But it amounts to a change of the modeling assumptions rather than to a change in the system.
This is exactly the same what people handling stocks do - they use propbabilities based on the most recently available information to make predictions, hence collapse their model probability distributions each time new information comes in. But I have never heard of a financial analyst complain about the weirdness of classical stochastic modeling.
Weirdness appears only when one mistakenly ascribes the collapse to the system rather than to the change in the model.
I believe the issue here is precisely that this comparison with classical stochastic modelling undermines the distinction you keep between change in the system and change in the modelling assumptions. That would be valid in Newtonian physics where measurements don't affect the system that is measured, but this is a key feature in QM and also in stochastic modelling where information directly affects the stock market.
It seems to me that your axioms simply ignore this difference because they might be tied to the classical mindframe.
But detector is usually put only on the final point in the path of the photon, while wave function is described during the whole path.
Demystifier said:
Of course, but @vanhees71 does not have any objections against updating. He only objects against collapse. To clarify his opinion, I have defined the notions of "update" and "collapse" in a manner consistent with his own understanding of those words.
As I understand, vanhees71 objects to collapse on grounds of locality. I think that is not a correct reason to object to collapse (one can object to collapse for other reasons, eg. on reasons of ontology, under the hypothesis that Bohmian mechanics is correct).
Particularly I object against claiming that there is an interaction at a distance, where there is none, as in the case of measuring the polarizations of entangled photons at far distant places. The interaction of the photon with the measurement devices are, by construction, local. Thus, there's now instantaneous effect of A's measurement on B's photon and vice versa.
The other case, discussed today, is about having three polarization filters (first H then ##\pi/4## then V in direction of the photon beam). Of course, here you have indeed local interactions leading to a change in the photon's polarization if going through or to its absorption if not going through. These are all caused by local interactions of the photons with the polarization foil.
Locality is a word with many different meanings, and he does not insist on all possible kinds of locality. He only objects against non-locality which contradicts Schrödinger equation, unless it is an update.
Again, you have to be more precise in what you are saying! I deny the existence of nonlocal interactions (or "actions at a distance") in standard relativistic QFTs, because they are explicitly formulated with local interactions. Of course, there is the possibility of correlations between far-distant parts of an extended system like the here discussed polarization-entangled biphoton states. Here I deny collapse, because a local interaction of A's photon with her measurement device does not instantaneously affect B's photon's properties measured a far distance away from A.
The Schrödinger equation describes action at a distance. It's a non-relativistic theory!
So? Experimentalists describe changes of wave-function along the path of photon beam and arrive at correct predictions. Where is the problem?
But the local interactions in QFT do not include the measurement apparatus. The Hamiltonian in the standard Bell test only includes the photons, which is why the state can be written ##|hh \rangle + |vv \rangle##.
So the Hamiltonian has nothing to say about collapse.
By Schrödinger equation, I mean any equation of the form
$$H|\psi(t)\rangle = i\hbar\frac{\partial |\psi(t)\rangle}{\partial t}$$
where ##H## is the Hamiltonian of the considered system. Even relativistic QFT has a Hamiltonian.
No problem. :smile:
The interaction of photons with anything is described by QED, at least I have no example, where this is clearly disproven. If collapse is not a dynamical process, it's simply not relevant to the entire discussion about measurement processes and state preparations.
Non local interactions in QED are hidden under change of basis.
What I would like to understand is: at the LHC - what is governed by unitary evolution? If you say there is no wave function of the universe, and no wave function of the LHC, then what is the biggest thing you are willing to assign a wave function to?
As long as there are artificially two kinds of evolution in QM, one by measurement and one in between measurements there is no way out of these eternal debates.
Let's hope the new formalism that may eventually arrive has the flexibility to model what all the quantum phenomenology shows, just one type of quantum evolution, the one observed.
I don't think so. The settings of the polarizers is relevant to the outcome and should be included in the Hamiltonian. It doesn't make much difference in any case, but it does not support collapse as a physical process ( in my opinion, anyway ).
In this regard I disagree with you and agree with @atyy . But to explain why I disagree I would need to talk about ontology, which is something you don't really care about. So I can't explain my reasons for disagreement in a way you would care about.
No, by construction the interactions are local in QED.
You cannot even describe the LHC by classical mechanics of each atom it consists of, and even if you could, it's a total overkill to do so. Nevertheless the classical theory of macroscopic observables is just an effective theory of QT for the relevant degrees of freedom to describe (even construct) the LHC.
