Thermal Expansion: Finding common temperature (Ring/Sphere)
The forum discussion centers on calculating the common temperature at which the inner diameter of a steel ring is 0.05% smaller than a lead sphere. The lead sphere has a diameter of 5 cm and a coefficient of linear expansion (α) of 29x10-6/°C, while the steel ring has a diameter of 4.9975 cm and α of 12x10-6/°C. The initial temperature (T0) is 70°C. The calculations reveal that the final temperature (Tf) should be 11.2766°C, but various attempts yield slightly different results, indicating the complexity of thermal expansion calculations.
  • Understanding of thermal expansion concepts, specifically linear and volumetric expansion.
  • Familiarity with the formula Af = Ao(1 + 2αΔt) for area expansion.
  • Knowledge of how to manipulate equations to isolate variables, particularly Δt.
  • Basic proficiency in algebra and unit conversions in thermal physics.
  • Study the principles of linear and volumetric thermal expansion in detail.
  • Learn how to apply the formula for linear expansion in practical scenarios.
  • Explore the impact of precision in measurements on thermal expansion calculations.
  • Investigate the differences between area and volume expansion and their applications in engineering.
Students in physics or engineering disciplines, particularly those focusing on thermodynamics and material science, as well as educators teaching thermal expansion concepts.
paulie
Find the common temperature at which the inner diameter of the ring is 0.05% larger than the diameter of the sphere.
Given:
Lead sphere
d = 5cm
To = 70°C
∝ = 29x10-6/C°
Steel ring
d = 4.9975cm (the sphere is 0.05% larger than the inner diameter of the ring, hence this value)
To = 70°C
∝ = 12x10-6/C°
Af = Ao(1+2∝Δt)
Δt = Tf - To
Equate both final area of sphere (S) and ring (R)
AFR = AFS (1.0005)
Substitute
Af = Ao(1+2∝Δt)
AoR(1+2∝RΔt) = (1.0005)AoS(1+2∝SΔt)
Arrange equation to find Δt
Δt = (1.0005)(AoS) - (AoR) / 2(AoR)(∝R) - (1.0005)(2)(AoS)(∝L)
Enter the values
Δt = (1.0005)(π(5cm/2)2) - (π(4.9975cm/2)2) / 2(π(4.9975cm/2)2)(12x10-6/C°) - 2(1.0005)(π(5cm/2)2)(29x10-6/C°)
The answer is
Δt = -44.0416 C°
Which is incorrect because the Final temperature is supposed to be 11.2766°C, using my answer and finding for the final temperature with 70°C as initial.
Tf = 25.9584°C
EDIT:
I've found out that if I multiplied 1.0005 on the diameter of lead sphere (5cm) immediately before others, I'll get an answer of Δt = -58.6820 C° where the final temperature will be 11.3180°C which is pretty close but not the exact answer :(
In the case of ring, you have to consider linear expansion, not the areal expansion. Similarly in the care of sphere you have to consider volume expansion.
Linear expansion for both.
@rl.bhat I tried using volume and linear but I arrived with a bigger value.
@mjc123 Tried to make both linear and I arrived with Δt = - 58.7521 C° which is pretty good, finding the final temperature I got 11.2473 °C although the given correct answer is 11.2766 °C. I'll try to recompute later.
The problem is actually one out of four question, I used area of expansion on the three others and found the exact correct answer. This is the last question and I'm having trouble in getting the exact value (11.2766 °C).
The question statement violates the usual rules of specifying accuracy. E.g. it should give the lead diameter as 5.0000cm.
Having extended all the data to that accuracy, you might think that the answer can be given to that accuracy, but not so. In this question, small differences are calculated between numbers of similar magnitude. E.g. 5.0025-4.9975=0.0050, so 5 digits of accuracy falls to only two.
Thus, it does not really make any sense to quote the answer more precisely than 11°C.
But for what it is worth, I get 11.256. If you care about that difference, please show exactly how you calculated it.
That was what I was thinking but it bothered me that it was the only answer that didn't exactly gave the exact value from the answer sheet. Thanks for the help guys.
  • · Replies 16 ·
10K
