Thermal expansion of bimetallic strip
The discussion centers on the thermal expansion of a bimetallic strip composed of two metals with coefficients of thermal expansion α1 and α2. As the temperature increases from T0 to T0 + ΔT, the strip curves due to differential expansion. The relationship between the radii r1 and r2 is established through the equations r1θ = L0(1 + α1ΔT) and r2θ = L0(1 + α2ΔT), leading to the conclusion that r1 = d/((α2 - α1)ΔT). The importance of retaining first-order terms in the expansion equations is emphasized for accurate calculations.
  • Understanding of thermal expansion concepts
  • Familiarity with bimetallic strip applications
  • Basic knowledge of calculus for approximations
  • Ability to manipulate algebraic equations
  • Study the principles of thermal expansion in materials
  • Learn about the applications of bimetallic strips in thermostats
  • Explore mathematical approximations in physics
  • Investigate the effects of temperature on material properties
Students in physics or engineering, materials scientists, and professionals working with thermal systems or bimetallic devices will benefit from this discussion.
PeppaPig
[/B]
A bimetallic strip is made of metal which has coefficient of thermal expansion is equal to α1 and the other's is equal to α2 at the temperature of T0. The temperature is increased to T0 + ΔT (ΔT > 0). The strip curves as shown in the figure. If both strip have the same width of d. Find r1 measured from the center of the curve to the center of the strip as shown in the figure
1) radian is (Length of the curve)/(Radius)
2) Using the following estimation
(1 + x)-1 ≈ 1-x and (1 + ax)(1+bx) ≈ 1+(a+b)x for x << 1
α1 strip expansion is L0(1 + α1ΔT) for the length
and d(1 + α1ΔT) for the width
α2 strip expansion is L0(1 + α2ΔT) for the length
and d(1 + α2ΔT) for the width
Multiplying radian with radius, the result should be the curve length
r1θ = L0(1 + α1ΔT)
r2θ = L0(1 + α2ΔT)
r2 = r1 + d(2 + α1ΔT + α2ΔT)/2
Is that correct?
What is the ratio of r2 to r1? What is the difference between r2 and r1?
The difference is d(2 + α1ΔT + α1ΔT)/2 because of the width expansion.
Is that correct?
Is that correct?
Neglecting the change in thickness, it is just d.
Then the difference should be d. And the ratio should be (r1 + d)/r1 or (1 + α2ΔT)/(1+α1ΔT)
Is that correct?
Yes. To terms of 1st order in ##\alpha \Delta T##, this gives $$\frac{d}{r_1}=(\alpha_2-\alpha_1)\Delta T$$
Thank you.
Which mean r1 is equal to d/((α2 - α1)ΔT)
What about the estimation? Or do I have to estimate them before the calculation?
PeppaPig said:
Thank you.
I don't know what you mean by "the estimation." Are you talking about retaining only terms of first order in ##\alpha \Delta T##?
Ok. That’s what we did with the equation in post #5.
Then it should be 1/(1 - α2ΔT)(1 + α1ΔT) and then 1/(1+(α1 - α2)ΔT)
Is that correct?
Is that correct?
Yes. So, from that, what is d/r1?
##\frac{d}{r_1} = \frac{-(\alpha_1 - \alpha_2) \Delta T}{1 + (\alpha_1 - \alpha_2) \Delta T}##
Then ##r_1 = (\frac{1}{(\alpha_2 - \alpha_1) \Delta T} - 1) d##
Is that correct?
Is that correct?
No. Check your math.
From these equations
##r_1 \theta = L_0 (1 + \alpha_1 \Delta T)##
##r_2 \theta = L_0 (1 + \alpha_2 \Delta T)##
Then substitute ##r_2## with ##r_1 + d##
##\frac{r_1 + d}{r_1} = \frac{1}{1+(\alpha_1 - \alpha_2) \Delta T}##
Where am I going wrong?
$$\frac{r_1 + d}{r_1} = 1+(\alpha_2 - \alpha_1) \Delta T$$
$$1+\frac{d}{r_1}= 1+(\alpha_2 - \alpha_1) \Delta T$$
Oh! I should estimate the equation into
##1 + (\alpha_2 - \alpha_1) \Delta T##
##r_1 = \frac{d}{(\alpha_2 - \alpha_1) \Delta T}##
Is that correct?
Is that correct?
Yes. It all involves knowing how to make the correct mathematical approximations.
Thank you very much and Merry Christmas.
Back at ya.
13K
