Thermal Processes: Ideal Gas Expansion with Constant Pressure [SOLVED]
  • Thread starter Thread starter HELLO11
    Thermal
The discussion revolves around a thermal processes problem involving the expansion of a monatomic ideal gas at constant pressure. The original poster seeks assistance in calculating work done, initial and final temperatures, change in internal energy, and heat added during the process.
  • Participants discuss using the ideal gas law to find temperatures, with references to specific equations related to internal energy and heat transfer for a monatomic gas.
Participants have provided guidance on using the ideal gas law and relevant equations for internal energy and heat. There is an ongoing exploration of how to calculate the initial temperature and the application of the ideal gas law.
There is mention of specific values for Cv and Cp for a monatomic gas, as well as the need for careful unit management in calculations. The original poster has confirmed the work done but is still seeking clarity on other aspects of the problem.
HELLO11
[SOLVED] Thermal Processes
With the pressure held constant at 240 kPa , 42 mol of a monatomic ideal gas expands from an initial volume of 0.75 meters cubed to a final volume of 2.0 meters cubed.
a)How much work is done by the gas during expansion?
b)What were the initial and final temperatures?
c)what was the change in the internal energy of the gas?
d)How much heat was added?
I know the anwser for a) is 3.0*10^5
i can't find the other three
can someone please help
Where have you looked?
Use ideal gas law: PV = nRT. You know P, V and n so just work out T for intial and final states.
What is Cv for a monatomic gas? How is [itex]\Delta U[/itex] related to Cv and [itex]\Delta T[/itex]?
Use first law: dQ = dU + dW
As a short-cut, since it is a constant pressure process, you can just use: dQ = CpdT. What is Cp for a monatomic gas?
Units?
AM
the units for the first answer are Joules
How do i wotk out the T for inital and final states
the Cv for a monatomic gas is 12.465
delta U is 3/2*n*R*deltaT
Cp for a monatomic gas is 20.775
Use the ideal gas law PV=nRT like Andrew suggested in post #3. You were given all the information you need to solve this for T.
For T i get 859.5 How do i get the inital temperature
You just use the ideal gas law twice. Once for the initial state (so before it expands), and once for the final state (after it expands).
Be very careful with your units.
thanks for all your help
  • · Replies 33 ·
