Thermodynamic Question (refrigerator)
The discussion focuses on calculating the electrical power used by an ideal refrigerator that removes heat at a rate of 0.15 kW from an interior temperature of 1°C, exhausting heat at 45°C. The coefficient of performance (COP) is established using the formula COP = Qc/(Qh - Qc), where Qc is the heat removed and Qh is the heat exhausted. The efficiency derived from the Carnot cycle is clarified as not being applicable directly to refrigeration cycles, emphasizing the use of COP instead. The final step involves determining the work done (W) using the relationship W = Qh - Qc.
  • Understanding of thermodynamic cycles, specifically the Carnot cycle.
  • Familiarity with the concept of Coefficient of Performance (COP) in refrigeration.
  • Knowledge of heat transfer principles and temperature scales.
  • Basic mathematical skills for manipulating thermodynamic equations.
  • Study the derivation and applications of the Coefficient of Performance (COP) in refrigeration systems.
  • Learn about the Carnot cycle and its implications for real-world refrigeration efficiency.
  • Explore the relationship between heat transfer rates and electrical power consumption in refrigeration.
  • Investigate advanced thermodynamic concepts such as exergy and irreversibility in refrigeration cycles.
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in the design or analysis of refrigeration systems will benefit from this discussion.
gotrilum
I'm having a little trouble in completing this problem. I would appreciate your answer if anyone knows how to solve it. Thanks
An ideal refrigerator removes heat at a rate of 0.15kW from an interior temperature of 1 degree celsius. The exhaust from the refrigerator is 45 degrees celsius. How much electrical power is used.
*Note that this is a refrigerator problem (reverse process from a carnot engine)
I have found the efficiency using Th/Tc - 1 = .29 I do not know how to proceed after this.
Remember efficieny is always
what you get / what you pay for.
so in this case its
Ql/Win
and for the reversible carnot this comes to:
COP = Ql/(Qh-Ql)
You must remember the for refrigiration cycles its not technically efficiecny, its coefficient of performance we use. This avoids the confision of having efficienys over 100%.
Where you were going wrong was you were taking the efficieny for a carnot cycle and applying it directly.
Coefficient of Performance is Qc/W. W = Qh - Qc.
So:
COP = (Qc /(Qh - Qc)
1/COP = Qh/Qc - 1
For a Carnot cycle, this becomes:
1/COP = Th/Tc - 1
You have to determine the COP from the temperatures. Using the value for Qc you can determine W.
AM
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 20 ·
