Thermodynamics: Calculating the work done
6 replies · 3K views
Saitama
One mole of a certain ideal gas is contained under a weightless piston of a vertical cylinder at a temperature ##T##. The space over the piston opens into the atmosphere. What work has to be performed in order to increase isothermally the gas volume under the piston ##n## times by slowly raising the piston? The friction of piston against the cylinder walls is negligibly small.
Work done in isothermal process is
[tex]nRT\ln\frac{V_2}{V_1}[/tex]
In the given question, ##n=1 \text{mol}## and ##V_2=nV_1##. Hence work done is:
[tex]RT\ln n[/tex]
but this is wrong. :confused:
Hey Pranav!
You have calculated the work done on the gas, but you have omitted the minus sign.
So if you (slowly) extract an amount of energy equal to ##RT\ln n## from the gas, the process will be isothermal.
This is not the total amount of work.
Note that it is a bit hard to force a change and still getting energy back instead of putting it into it. :wink:
Where is the atmosphere in your equations?
I like Serena said:
Hey Pranav!
Thanks voko and ILS for the replies! :smile:
Okay, so there will be some work done on the atmosphere too. The change in volume of atmosphere is ##(n-1)V_1##. The work done on the atmosphere is ##PV_1(n-1)## where P is the initial pressure. Also ##PV_1=RT##, hence net work done is ##(n-1)RT-RT\ln n=RT(n-1-\ln n)##, correct?
This looks good to me.
