[Thermodynamics] Impossible Heat Transfer Problem
The forum discussion addresses a thermodynamics problem involving heat transfer between water and ice in an insulated Thermos. The initial calculations for the final temperature (77.63K) are incorrect due to the improper use of heat capacities. Specifically, the heat capacity of liquid water must be used in both terms of the denominator after the ice has melted. The latent heat of fusion (L) for ice is correctly identified as 334 J/g, which is essential for calculating the energy required to melt the ice.
  • Understanding of the first law of thermodynamics
  • Knowledge of specific heat capacity (c) for water and ice
  • Familiarity with latent heat of fusion (L) for ice
  • Ability to perform calculations involving mass (m), temperature change (ΔT), and energy transfer
  • Review the concept of specific heat capacity for different states of matter
  • Learn about the latent heat of fusion and its applications in thermodynamics
  • Study the first law of thermodynamics and its implications for closed systems
  • Practice solving heat transfer problems involving phase changes
Students and professionals in physics, engineering, and environmental science who are studying thermodynamics and heat transfer principles.
Gr33nMachine
An insulated Thermos contains 122 g of water at 91°C. You put in a 13.7 g ice cube at 0°C to form a system of ice + original water.
Use mc(ΔT) |water + mc(ΔT) |ice + Lm |ice = 0
Final T = [(m*c*T) |water + (m*c*T) |ice - (L*m) |ice] / [m*c |water + m*c |ice]
Final T = [(.122*4.18*364) + (.0137*2.108*273) - (334*.0137)] / [.122*4.18 + .0137*2.108]
[STRIKE]Final T = 77.63K[/STRIKE]
IS WRONG
What am I doing wrong??
assuming you went from
to
What is L and why is it 334.
IS WRONG
In the denominator, you should be using the heat capacity of liquid water in both terms, since the ice is melted.
10K
