TLewis
- 2
- 0
I have been over and over this and I need some help.
I have a copper wire (.0019 inch diameter) running in a wire preheater. I heat the wire at 24 volts AC, 800Hz and pull 192 amps. The wire is approximately 1 meter in length and is moving at 2500 ft/sec. The ambient temp. is 73 deg. F.
What is the temperature of the wire?
I know the "black body radiation law" applies here but this is what I am after;
What is an approximating equation I can use to determine the wire temp if I know the following:
Diameter of the wire
Voltage applied
Current measured
Frequency of the source voltage
Emissity of the copper
Wire speed
Wire length 1 meter
Ambient temperature
I am collecting all of the above in a PLC application and want to approximate the exiting wire temp. What about just in a steady-state condition?
I know, this is pretty long hair, but I know there are real engineers/ physics majors that know the laws of thermodynamics and might be able to give me some direction.
thank you
Voltage applied
Current measured
Wire speed
Wire length 1 meter
Ambient temperature
thank you
