Can You Calculate Room Temperature Increase With Given Heat Output and Airflow?
  • Thread starter Thread starter JackA7X
    Thermodynamics
The discussion centers on calculating the temperature increase in a room based on a bulb's heat output (Q W), the room's volume (V m3), airflow rate (F m3/s), and the intake air temperature (T °C). To accurately determine the temperature rise, additional information such as the specific heat capacity of air and the duration of heating is necessary. The calculation can be approached using the formula ΔT = Q / (ρ * V * cp), where ρ is the air density and cp is the specific heat capacity of air.
  • Understanding of thermodynamics principles
  • Familiarity with heat transfer calculations
  • Knowledge of specific heat capacity of air
  • Basic algebra for manipulating equations
  • Research the specific heat capacity of air at different temperatures
  • Learn about heat transfer equations in thermodynamics
  • Explore airflow dynamics and its impact on temperature distribution
  • Study the effects of insulation on room temperature changes
Engineers, HVAC professionals, and anyone involved in thermal management or environmental control in buildings will benefit from this discussion.
JackA7X
So I have a bulb with heat output Q W.
Room volume of V m^3
Air output of F m^3/s
Air intake temp T Deg.
Is it possible to calculate the temp increase of the room? Would you need more information?
Assume normal air density etc
  • · Replies 45 ·
  • · Replies 34 ·
  • · Replies 40 ·
