Thermodynamics: Two gases in a container
1 reply · 1K views · last reply
heyhey281
Consider
a) two gases, each in a container with volume V
b) two gases in a container with volume V
Which system is more disordered, where is the entropy higher?
Ideal gas equation
(Van der Waals equation)
Ideal gas:
If the gases are of different type, I would say the entropy stays the same. The total entropy is in both cases just the sum S = S1 + S2, where S1 is the entropy of the first gas and S2 the entropy of the second gas.
If the gases are of the same type, I think the entropy change is also 0.
(I am not too sure if you can even distinguish ideal gases / call them different types?)
Real gas:
Due to the intermolecular forces, I think the molecules might "cluster" a little bit more which would lower the entropy? But on the other hand, I could first put both gases into the common volume V and hypothetically assume that there is absolutely no interaction between them ("switch off" the interaction between them before I mix them). Then I could “switch on” the interaction and wait until an equilibrium is reached. Since the system is isolated, the entropy cannot have possibly decreased?
heyhey281 said:
I am not too sure if you can even distinguish ideal gases - - -
In what sense? Your body does it all the time. You keep some of the oxygen that you breathe in and you breathe out carbon dioxide.
More to the point, I think you need to consider entropy of mixing.
