Thermofluids, Viscous Flow Problem
3 replies · 3K views
Bob Harrison
Q.2 One type of bearing that can be used to support very large structures is shown below. Here fluid under pressure is forced from the bearing midpoint (A) to the exterior zone B. thus a pressure distribution occurs as shown. For this bearing which is 30cm wide, what discharge of oil from slot A per meter of length of bearing is required? Assume a 50kN load per meter of bearing length with a clearance space t between the floor and the bearing surface of 0.6mm. Assume an oil viscosity of 0.2 NS/m2. Hour much oil per hour would have to be pumped per meter of bearing length for the given conditions?
Can anyone help me here? I am completely stumped at where to begin, only just begun our lectures on viscous fluid flow.
Have they covered pressure driven flow between parallel plates in your course yet? If so, what is the relationship between the pressure gradient and the average velocity?
Chet
Chet
Not really, our lecturer said that he didn't expect us to be able to solve some of these questions completely. But I'd like to get a head start so if you're able to help explain me how to obtain a solution that'd be much appreciated :).
See if you can follow this development: http://farside.ph.utexas.edu/teaching/336L/Fluidhtml/node108.html
Chet
