Three Blocks on Frictionless Incline(Please check work)
Three blocks are pushed up a frictionless incline at a 30-degree angle with a constant acceleration of 3.0 m/s². The discussion centers on determining the forces between the blocks and the external force acting on Block A. It is clarified that the force Block A exerts on Block B is equal to the force Block B exerts on Block A, contradicting the initial assumption. The correct external force exerted on Block A is calculated to be 31.6 N, with a note that the gravitational force should use 9.81 m/s² instead of 10 m/s² for accuracy. Overall, the calculations and understanding of Newton's laws are emphasized for clarity in solving the problem.
ryan1180
Three blocks are pushed up a frictionless plane that is inclined at an angle of 30 degrees with respect to the horizontal as shown below. The blocks move together with constant acceleration a = 3.0 m/s2. The masses of the blocks are: MA = MC = 1 kg, and MB = 2 kg. The next three questions pertain to this situation.
[PLAIN]https://online-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys100/fall10/hwb/06/01/fig4.gif
The magnitude of the force that block A exerts on Block B is greater than the magnitude of the force that block B exerts on Block A.
TRUE
FALSE
Compare FAonB, the force Block A exerts on Block B, to FConB, the force Block C exerts on Block B,
FAonB < FConB
FAonB = FConB
FAonB > FConB
What is the value of F, the external force that is exerted on Block A?
F = 3.0 N
F = 4.9 N
F = 12.0 N
F = 31.6 N
F = 39.2 N
Fnet=ma
(Newton's laws)
I have found answers for the questions, I'd just like my work to be checked
Part 1:
False, because Newton's second says for each force there is an equal and opposite reaction, therefore meaning the forces must be equal
Part 2:
Faonb>Fconb
Looking at the diagram, Faonb is greater because it has the forces of two blocks acting on it as opposed to just one in Fconb, follow Newton's second again.
Part 3:
I used F=ma
F-40sin(30)=4(3)
to get 31.6 N
If anyone could check my work it would be much appreciated!
It's almost correct, you miscalculated part 3. F = ma + mgsin30 = 4*3 + 4*10*0.5 = 12+20 = 32N. I don't know how you got 31.6...
EDIT: sorry, I didn't realize part 3 also had options:) Yeah 31.6 is correct, but in your equation it shouldn't be 40sin(30), but 4*9.81*sin(30), you get 31.6 that way.
Yeah, I had calculated it with 10 m/s^2 and then changed it to 9.8 but forgot to change it on my note sheet that I'm working the problems out on.
Thanks!
