Calculate Currents & Power in 3-Phase Systems w/ Star-Connected Load
The discussion focuses on calculating currents and power in a balanced three-phase system with a star-connected load, specifically using a line voltage of 415V and impedances Za = 10 - j10, Zb = 10 + j10, and Zc = 0 + j8. Participants clarify the calculation of phase and neutral currents, emphasizing the importance of correctly determining the angle of Zc, which is 90 degrees due to its purely imaginary nature. The total power dissipation is derived using the formula P = Ea x Ia x cos(Φa) + Eb x Ib x cos(Φb) + Ec x Ic x cos(Φc), highlighting the significance of accurate angle measurements in power calculations.
  • Understanding of three-phase electrical systems
  • Familiarity with complex impedance and phasor representation
  • Knowledge of power calculations in AC circuits
  • Proficiency in using vector diagrams for complex numbers
  • Study the calculation of neutral currents in star-connected loads
  • Learn about the implications of angle measurement in complex impedance
  • Explore the use of vector diagrams for analyzing AC circuits
  • Investigate the impact of load imbalance on three-phase systems
Electrical engineering students, professionals working with three-phase systems, and anyone involved in power system analysis and design.
Mathn00b!
Hello, I am given the following problem.
A balanced three phase 4 wire supply has r.m.s. line voltage of 415V and supplies a star-connected load made of 3 impedances:
Za = 10 - j10; Zb = 10 + j10; Zc = 0 + j8;
Calculate the current phase and neutral currents, also the total power dissipation. [NOTE: Assume that Va is drawn vertically up, i.e. its phase angle is 90]
I've used Vline = √3 x Vphase
Also, P = Ea x I a x cos(Φa) + Eb x I b x cos(Φb) + Ec x I c x cos(Φc)
Please find the attached file, as my solution to the problem. As it could be seen the answer is quite different. In fact their answer is just the sum of the 1st two bits of the power, ignoring the last one. I assume they used cos(90) to get 0 and hence lower power. If this is the case, then the Zc should look like 8∠90° .
But isn't it found from the equation : Zc = √02 + 82 ∠tan-1 (8/0) ?
http://i1375.photobucket.com/albums/ag441/gl0ck1/StarLoad_zpslnhuotig.jpg
Error: The requested attachment could not be found.
You must find the center voltage, En, at the center of the star-load.
Then:
Ia = ( Ea - En ) / Za , etc.
( I think? I cannot see if the center of the star-load is connected to neutral )
Strange, just sent it to one of my friends, he was able to open it. Will post a photobucket link just in a sec.
I am asked to find the neutral current, which could be found from the sum of all currents, no?
I've been able to open it now (error disappeared).
You may argue: If neutral is not connected to center of the star-load, then In = 0.
But I've found an error: Zc = ( 0 + j8 ) = 8 / 90°
Could you please, explain to me how you found it to be 8 ∠90°? What formula did you use? Isnt't it the same I used at the 1st post of the thread Zc = √02 + 82 ∠tan-1 (8/0) ? and tan-1 (0) = 0.
I presume it is connected since I've been asked to find it.
I'm not using any formula: Draw the vector ( 0 + j8 ) in the complex plane and measure the angle ( or you can see it by intuition ).
( Contrary: ( 8 + j0 ) = 8 / 0° )
The angle you've associated with Zc is incorrect. As a result the angle calculated for ##I_c## is incorrect.
The angle calculated for ##I_a## is incorrect.
Yes you are right, it should be 135, but really don't understand the Zc's angle. Should I do it always like that? Drawing a vector, when the real part is zero?
It certainly can be helpful to sketch a vector for a complex value in order to get an idea of what the angle should be (such as the quadrant it lies in). But you should know that any purely imaginary number must have an angle of either + or - 90 degrees.
Thank you both for the replies!
