What is the height of a ball after being in the air for T/4 seconds?
  • Thread starter Thread starter robax25
    Ball
The height of a ball after being in the air for T/4 seconds can be calculated using the kinematic equation y = v_0 t + 0.5 a t². Given that the total time in the air is T and the maximum height is H, the ball reaches its maximum height at T/2 seconds. The height at T/4 seconds is determined to be H/4, but further calculations involving initial velocity (v_0) and acceleration (a) are necessary for precise results. It is crucial to maintain consistent notation, using either g or a for acceleration due to gravity.
  • Kinematic equations of motion
  • Understanding of projectile motion
  • Basic algebra for solving equations
  • Concept of maximum height in vertical motion
  • Study the derivation of the kinematic equation y = v_0 t + 0.5 a t²
  • Learn about projectile motion and its characteristics
  • Explore the concept of initial velocity in vertical motion
  • Investigate the effects of air resistance on projectile motion
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion.
robax25
A child tosses a ball directly upward. Its total time in the air is T. Its maximum height is H. What is its height after it has been in the air a time T/4? Neglect air resistance.
y=volt +0.5 at²
It is 1/4 H but I don't get exact answer.
y=volt +0.5 at²
What answer do you get? Please show.
At what time do you think the ball reaches the maximal height H?
t/2 second
robax25 said:
t/2 second
What value are you able to obtain with that information and the equation you posted in section 2 of the template in your first post?
y=v(t/2)-0,5a(t/2)² when the ball is at maximum height and vo is equal to gt/2
So, you can find ##t## from the first equation (using ##y = H##, a given input in the problem); then, after finding ##t## you can figure out ##v_0##. Take it from there.
By the way: either use ##g## or ##a##, but not both notations in the same problem, given that they are both supposed to be the same quantity.
Stay with the definition that ##v_0## is the velocity of the ball when it leaves the child's hand, which is what you want to calculate to find the answer of the original problem (##v_0=f\left(g, T, H\right)##).
There is no need to find the initial velocity.
robax25 said:
t/2 second
What is t? Why did you add "seconds"?
I guess you mean T/2 - just half of the total air time. That is correct.
Consider the second half of the motion for a moment: How can you describe how far it fell down from the highest point as a function if time?
It drops down by H over a time of T/2. How much does it drop down in half of that time, in T/4? While that is not the final answer to the problem you can transfer that result to get the right answer.
  • · Replies 38 ·
