Undergrad Rocket Thrust: Power Your Launch Into Space
  • Thread starter Thread starter TkoT
    Rocket Thrust
The discussion centers on the reference frame of a rocket, emphasizing that using the rocket's frame simplifies calculations. There is confusion regarding the formula for exhaust velocity relative to the rocket, with a correction noted that it should be "v" instead of "u." The relationship between the rocket's speed after expelling exhaust and the velocity of the ejected material is clarified as v + delta v - U. The source of this information is linked to HyperPhysics. Overall, the conversation highlights the importance of clarity in reference frames and velocity calculations in rocket physics.
TkoT
TL;DR
Confusion of thrust of a rocket
I saw the information of thrust of a rocket in the hyperphysics website, but I cant understand it.
1.why do the problem need to observe in two frame ( from an external framework and rocket frame of)?
2.why do the exhaust velocity relative to the rocket u=u+deltav-U?
Thank You
Likes berkeman
The reference frame of the rocket is the easiest one. You can always choose whatever reference frame you want but why make it harder than needed?
Where do you get that from? The exhaust velocity relative to the rocket is u which is not equal to u+deltav-U.
Likes TkoT
mfb said:
The reference frame of the rocket is the easiest one. You can always choose whatever reference frame you want but why make it harder than needed?Where do you get that from? The exhaust velocity relative to the rocket is u which is not equal to u+deltav-U.
typo,why do the exhaust velocity relative to the rocket u=v+deltav-U? should be "v" not "u".
i get the information from this website: http://hyperphysics.phy-astr.gsu.edu/hbase/rocket.html#c1
thank u for your reply
The rocket speed after expelling the exhaust is v+delta v, the ejected material moves at U by definition. They just calculate the difference, which is v + delta v - U
Likes TkoT
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 68 ·
  • · Replies 17 ·
  • · Replies 62 ·
  • · Replies 18 ·
